Results 1 to 8 of 8
Thread: WTB: Looking for 1969 2.0S engine 901/10
    Senior Member Lazza911's Avatar
    May 2012
    Valpolicella hills
    Complete engine or cases.
    Thanks for help
    May 2012
    Valpolicella hills
    This is to bump it up!
    May 2012
    Valpolicella hills
    Still looking for a complete engine or 901/10 case
    Thanks, ciao!
    Hi,
    I have a complete, disassembled 901/10 engine from flywheel to Weber carbs. One of the rod bearings was damaged as well as the crank. It is at standard specs and is rebuildable. What would you consider offering?
    Let me know if you are interested.
    Regards,
    Joseph
    May 2012
    Valpolicella hills
    Hi Joseph, a standard 901/10 is on FMI, not Weber. Was it modified to get a better howl?
    Would be nice to have some pictures of the parts, particularly the damaged ones to evaluate the job to be done.
    Where are you placed? Can you give me serial and build nr.?
    Thanks, kind regards
    Andrea
    May 2012
    Valpolicella hills
    Joseph, would be nice to have your answer. Please pm me if you like
    May 2012
    Valpolicella hills
    Always happy to check your proposals...
    It would be good to find 901/10 cases in good shape, but also a complete motor would be very welcome!
    May 2012
    Valpolicella hills
    A sunny bump from our magnificent Valpolicella hills!
