Results 1 to 8 of 8
Thread: WTB: Front Sway Bar Mounting Plates
    Looking for a pair of front sway bar mounting plates for a factory 15 mm set up. Let me know what you have.
    Many thanks
    May 2006
    Riverside CA 92505
    Quote Originally Posted by nickR View Post
    Many thanks
    Which plates do you need? The cars have the plates welded in.
    The sway bar levers?
    looking for a pair of these.
    May 2006
    Riverside CA 92505
    Do not have any extras. I think they are still available new but are about $100 each.
    I have a complete sway bar kit from Porsche for a through the body bar. Drop Links, Sway Bar Body Brackets, hardware. Bought new from Stoddard and put away for a rainy day.
    Stabilizer Levers (2) 901 343 713 01
    Drop Links 901 (2) 343 076 03
    16mm? Bar 901 (1) 343 703 03
    Stabilizer Mounting (2) 901 343 754 01
    Guide Plates (2+2) 901 343 763 00
    Hardware
    Do the math:
    http://www.stoddard.com/911-1965-75/...t/swaybar.html
    Taking it to Hershey.
    Early S Registry #235
    rgruppe #111
    Can't be at Hershey but thanks anyway. Looks like I'll probably have to order a set from Stoddard.
    FWIW, here it is out of the box. You can see all that's needed to install one save for the sealing washer 901 343 766 00 and the nuts and bolts.
    rgruppe #111
    Thanks, that is very helpful.
