Results 1 to 10 of 16
Thread: My headlight switch burnt while reving...
    Aug 2012
    France
    All,
    My headlight switch melt suddenly while I was driving - I replaced it with a brand new one - on idle the headlights were on and no smell, then while reving smell of burn again....
    I wondered if a faulty regulator would cause this.
    I checked the battery charge at idle and 1500rpm, battery charge seems ok (nearly 15v - it is a 3.2 alternator)
    Checked the fuse panel, ok
    I noticed there is no relay.
    Any one faced this ?
    Cheers
    X
    O-G 26 - Early911S 2407
    Banned
    Nov 2004
    Scottsdale, AZ
    Anything over 14v starts getting dicey.
    90amp alternators have internal regulators. Try that right after you check all of your connections.
    Aug 2012
    France
    Thanks Franck, will do. I ckecked all cnx already.
    (how is the badge ?)
    X
    Banned
    Nov 2004
    Scottsdale, AZ
    lol
    My wife opened the package and gasped.
    "Who is THIS from?" still rings in my ears.
    Thanks for the memento!
    Dec 2008
    Woodland Hills, CA
    What headlights are you running?
    Aug 2012
    France
    Quote Originally Posted by gsjohnson View Post
    Stock ones, no fog, no additional high beams.
    Dec 2008
    Woodland Hills, CA
    Not even H4s?
    Aug 2012
    France
    right H4, was thinking of some additionals/custom etc...
    What do you have in mind ?
    X
    Dec 2008
    Woodland Hills, CA
    H4s need a relay(s) or they will fry your H/L switch. The wiring gets too hot. Ask me how I know...
    I installed this kit:
    http://www.jwesteng.com/shop/index.p...roller=product
    That fixes the problem. Too bad that relays are "not correct" on these cars...
