Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Fs: 1983 911sc $35,000
    Senior Member Macroni's Avatar
    Nov 2006
    Philadelphia PA
    Bought this coupe last summer.....
    104,000 miles
    Silver exterior
    Full leather black interior
    Very Good condition
    Performed long term maintenance @ Specialty Cars in Allentown
    including...
    • New Bridgestone tires and a set of 16 x 9" Fuchs (original 6s included)
    • Set Front and rear height/ 4whl alignment
    • Replaced dash board
    • Front and rear window seals
    • Replaced oil return tubes/cam tower oil lines & install oil fitting updates/ replace oil sender gasket and clean oil tank/ resurface engine oil sump cover
    • Installed original muffler and test pipe (original Cat included)
    • Replace paper heating hoses in engine compartment
    • Replaced plastic fuel tank vent hoses at fuel tank
    • Service trunk fuse panel and replaced all fuses w/ German ceramic fuses
    • Install Gel Battery
    • Replaced all shifter bushings, adjusted shifter and clutch
    • Changed Gear oil and replaced shift fork cover gasket
    • Replace Steering Column Bushings
    • Replace throttle bell crank bushings at trans and engine block
    • Adjust valves and torque cylinder head nuts
    • Replace fuel filter and set up engine (CIS)
    • Replace front and rear brake hoses and flush complete system
    • Service front wheel bushings
    • Remove both drive shafts and service CV joints
    • Update A/C system: replace all rubber A/C hoses, install A/C rotary compressor and receiver dryer / evacuate and charge system w/ 134A refrigerant.
    • Installed euro amber rear lenses
    Good honest coupe w/ working A/C that only requires routine maintenance. Got my eye on a tasty longhood.......
    LukeMaranoJr@philamacaroni.com
    86 Sport Purpose Carrera "O4"
    Apr 2010
    Kalimantan <SeaTac<Philly
    A very pretty platinum silver. Got a hint of gold/glow to the silver.
    Registry Member #2679 friggens's Avatar
    Jul 2013
    Albuquerque, NM
    Looks very nice. I like the color. What color is the interior?
    Jun 2011
    Western US.
    Great sorted car from a great sorted seller
    East Coast
    Jun 2009
    Philadelphia, PA
    Luke, my man...WTF are you doing selling this car? This is a great SC that is well sorted with AC that ACTUALLY works. Owned and maintained by a guy who knows how to get a car right......GLWTS..
    OG3
    RG715
    Nov 2006
    Philadelphia PA
    Thanks boys..... I will get color codes when I get home tonight and post......
    Interior is Black full leather w/ appropriate wear......
    Jul 2013
    Albuquerque, NM
    Quote Originally Posted by Macroni View Post
    That is a relief!! Nice...
    Luke,
    Beautiful car, GLWS.
    Phil
    Early S Junkie # 658
    Oct 2003
    Rhode Island
    Too nice to hotrod? Up next?
    '74 leichtbau
    "Sascha"
    R Grp 246
    S Reg 823
