Thread: Rear engine mount
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Rear engine mount
    What are the differneces thru the years? Are all the same or are they not interchangeable.....cliff
    64-73 (yoke)
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    First couple years the mount was a flat blade, starting in 67 the upper edge was formed to a right angle to provide more strength.
    Mar 2006
    8903one
    Actually, I'm referring to the central mount that the cross piece would connect. TIA. cliff
    That was also different, originally a stamping, then about the same time as the above change to the mounting blade the console also became a built up piece rather than the stamping.
    Mar 2006
    8903one
    engine console variance
Size:  69.3 KBName:  IMG_1272.jpg
Size:  87.9 KBEd, thanks for the clarification....I found another console that I had in the garage and wha-la..........
