Results 1 to 3 of 3
Thread: Seal/Shim under door striker plante, is it factory?
    Jan 2014
    Switzerland
    I found this under the door striker plate:
    Is it possible, that they are original for a early car. Mine is from february 1965.
    Maybe in the same way as the fender to cowl seals were made out of leatherette?
    Best regards from switzerland
    Marcel
    May 2014
    South East USA
    I think its a good idea for shim material.
    But, I think the holes would probably be better made.
    The 356 used fabric gasket on the torsion bar covers, so the idea of vinyl isn’t a far stretch.
    I have only ever seen plastic plates.
