Results 1 to 7 of 7
Thread: Wheel Fit For A Stock 70T
    Will a set of 16/6 and 16/7 Fuchs fit on a 70T that is completely stock?
    The short answer is NO.
    Jim,
    Short or not I appreciate the response. I take it that to use 16s, it would require some significant modifications to the suspension and/or body components. Again, thanks for the info and best regards.
    May 2005
    Oroville, CA
    Ditto,
    If you want to trade your 7X16s for 6X16s maybe I can help.
    We have done quite a few to look like 6X15s. They fit and work well with the tire selection available.
    H
    Senior Member M_deJong's Avatar
    Jan 2011
    DFW TX
    To add to what the others said, its not the 16's that are problem, it is the 7" width and the available tires. 6x16 all around with 205/55-16 will work great.
    Mike de Jong | '71 911T/E 2.4 Tangerine | '74 911S 3.2 Ice Green
    Apr 2003
    Portland, OR
    I am running 205/55-16 BFG g-Force Sport A/S tires on 16x6's Fuchs. Once I got my suspension squared away, no problems. I did have a slight rub but my car is lowered below USA Stock height. Per Steve Weiner, I went to Turbo Torsion bars and had the car properly aligned and corner balanced at Rothsport. The car works great.
    Harry
    Member #789
    1971 Jaguar XKE 2+2 V12 Coupe - {insert name here}
    2009 MB C300
    Florida
    Name:  911 @ HOMESTEAD 2007.jpg
    I'm going to take the other side here. I have 16x6 and 16x7 on my '73. I run 205/55-16 on all four corners.
    Richard Newton
    Car Tech Stuff
  1. stock steering wheel part or custom?
    By mepstein in forum Technical Info
    Last Post: 11-17-2013, 05:05 AM
  2. WTB: Fuchs stock wheel cap centers
    By Haasman in forum For Sale: 911 Parts
    Last Post: 07-25-2012, 11:36 PM
  3. WTB: Steering Wheel- Stock
    Last Post: 07-17-2012, 10:46 AM
  4. Best source to refinish a stock steering wheel
    By rpmooreii in forum Technical Info
    Last Post: 12-12-2010, 05:49 AM
  5. WTB: stock 400mm steering wheel (for a 73 911)
    By rpmooreii in forum For Sale: 911 Parts
    Last Post: 11-05-2010, 05:25 PM
