Thread: Wire harness rubber 'shroud' at rear
    Nov 2006
    S. F. Bay Area
    Harness has protective sheath around it under rear and in engine compartment. Mine's in 2 pieces. Correct or not? Is this available anywhere? Thx
    Brian
    S Reg #1032
    try these guys or maybe Mcmaster-carr.
    http://www.kroonwireharnesses.com/site/About_us.html
    solid sleeve
    search ed mayo and mcmaster
    1966 911 #304065 Irischgruen
    Dec 2008
    Woodland Hills, CA
    I may have some extra left over from my car. What is the length you need?
    Nov 2006
    S. F. Bay Area
    Ill measure. I don't even know if there is 1 or 2 (or more) pieces of it.
    Brian
    S Reg #1032
    Nov 2010
    Harleysville, PA
    Mine was in two pieces also. I think (without digging it out of the box) that it was held together with electrical tape at the point where they put a slit in it for a wire to exit.
    It cleaned up nicely with simple green.
    Mark
    1967 911S - 306465
    1980 911SC - Targa
    2005 Carrera Cabriolet - Ex. Porsche - Totaled!
    Nov 2006
    S. F. Bay Area
    Quote Originally Posted by gsjohnson View Post
    Total length = 54"
    Brian
    S Reg #1032
    Nov 2013
    hello.............
    welcome here
    I may have some extra left over from my car. What is the length you need?........................
    Top ten classified
  1. Replies: 3
    Last Post: 03-25-2014, 01:45 PM
  2. Installing wire harness…a few questions ('67)
    By Silverbullit in forum Technical Info
    Last Post: 11-13-2013, 08:25 PM
  3. Wire harness source?
    Last Post: 09-27-2012, 11:42 AM
  4. Need engine harness wire routing help!
    By Fritter in forum Technical Info
    Last Post: 04-12-2009, 04:44 PM
  5. Spark Plug Wire Holder to Fan Shroud - Where to Get?
    By t6dpilot in forum General Info
    Last Post: 10-17-2007, 12:38 PM
