Page 16 of 91 FirstFirst ... 614151617182666 ... LastLast
Results 151 to 160 of 907
Thread: Special early 1964 features on 1965 cars
  1. #151
    Nov 2002
    San Dimas, CA
    I took some photos of 300824 at Carparc USA's open house at the LitMeet:
    Name:  2015-03-07 15.44.10_ps.jpg
    If it can't be read on the website, it says "Production completion date, April 2, 1965"
    It has luggage hooks in the front trunk:
    Name:  2015-03-07 15.30.29.jpg
    Name:  2015-03-07 15.30.19.jpg
    I think this is the short grill:
    Name:  2015-03-07 15.55.08.jpg
    Name:  2015-03-07 15.55.00.jpg
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
  2. #152
    Senior Member earlyaircooled's Avatar
    Jun 2008
    Portland, OR
    My car #717 is an earlier number but was finished later, the spare wheel is dated 1-65. Name:  cardex.jpg
  3. #153
    Jun 2008
    Portland, OR
    Four more features that may be unique to early cars. 1. I think the front calipers are a bit different, Eric Shea said they are more like 356C calipers, which makes sense. 2. Also the area behind the horn grills seems to have a different shape and the cut out and area where the 4 holes for the 4 hole grill go are very crude. 3. I think the way the door locks are actuated from inside the car are different, there are double wires, almost like piano wire in a plastic tube. 4.The threshold step plate the part you step into to get into the car when you take the rubber threshold plate off I see rectangular depression, and on my car they were filled in with what looked like plaster like one would use for lath and plaster in an old house, I'm not sure body filler/bondo was invented by 1965? If not then they may have used plaster back then?
    Name:  front brakes.jpg
  4. #154
    Jun 2008
    Portland, OR
    the brake calipers dont say ATE on them like the later ones do
  5. #155
    Sep 2006
    La Quinta
    Good info...
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
  6. #156
    RHD 65's - 5 piece teak dash
    Quote Originally Posted by Bobs 67S View Post
    Adding some photos to distinguish features of the 6 piece and 5 piece wood dash.
    It would be a very good thing to define the change-over between car 567 and 835, (but 270 or so cars at approximately 15 cars per day is a 3.5 week window in March 1965). Nice work. Your list is getting very good information.
    The difference on the simplified dash eliminated not only the seam but the metal tab and wood nub that held the tab.
    Hi Bob,
    For reference my highly original '65 built in RHD has a 5 piece wood dash. Given we know of about a dozen RHD '65s this is likely a piece made to order in small quantities for the batches of RHD cars made; I heard from Alan Hamilton that the first four cars were literally hand made in the Werks dept in two batches of two starting Feb '65 (he was apprenticing at the factory at this time and saw the RHD's being built, including what became his car), which may explain why the early pattern ( but reversed !) was used for the wood dash.
    '65 901 SA '119' - 1st RHD Customer Delivered 911 Worldwide; 5710 Stone Grey/Green Leatherette 3 owners from new.
    '75 (Nov) 924 Group 4 Rallye. 9th o/all, 1st in class ‘79 Repco Round Australia Rally Barth/Kussmaul; 1st RHD chassis, 1st front engined Porsche to win an FIA event
    ‘78 928 Manual - early RHD Opalmetallic (gold) + Pasha
    '98 986
    ‘99 996 GT3 CS M003 ex Peter Fitzgerald. Falken livery. 2nd 2000, 3rd in 2001 Aus Nations Cup Championsip. Last of the road registered racers
  7. #157
    Jun 2008
    Portland, OR
    My car #717 has a 5 piece dash, door attaching bolts not allen heads, Here is a close up of the door lock mechanism
    cloth trimmed carpet
    door bolts
    rocker running board area
  8. #158
    EarlyAC,
    let us know if your "Karro" bolts holding the door hinges are 14mm across the flat, they sure look to be the original thing.
    It's looking like your rocker panels have original indent stampings.
    Show us the two part carpet clips that snap onto the floor. How many on the front carpet, rear carpet and the tunnel carpet?
    Your car is showing some real fun parts. Good stuff.
    Bob
    Early S Reg #370
  9. #159
    Jun 2008
    Portland, OR
    My doors are held on with 14mm Karro bolts
    Here are pictures of the floor matt snaps there are 4 on each side for a total of 8
    Name:  00 floor snaps  (2).jpg
    Name:  00 floor snaps  (1).jpg
    small gas door release knob
    Name:  00 floor snaps  (4).jpg
    rear deck lid release in round hole
    Name:  00 floor snaps  (5).jpg
    front hood release, please note unique board that it goes through, held on with two screws
    Name:  00 floor snaps  (8).jpg
  10. #160
    Senior Member pss's Avatar
    May 2014
    Netherlands
    Hi Jim and earlyAC, many thanks for yr info.
    Early AC, have added yr info below. Can you check the open items also, or even better send more great pictures? Would be fantastic. Your info is crucial to me personally as my car 700 is the same color and very close to yours. I now know for example that it should be black under the grill.
    I also have the same door release cables, but I have not seen the floor mat mounts before.
    What material is the air vent water collection tray under the wipers (grey plastic or some orange/brown fiber with resin) and do you have a short or long front vent drain tube (see post 101)?
    Cheers, Jacques
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
  1. FS: Very early 4 screw dash top 1964 - 1965
    By IAA1963 in forum For Sale: 911 Parts
    Last Post: 12-29-2019, 09:11 AM
  2. Replies: 29
    Last Post: 11-23-2019, 04:41 PM
  3. Replies: 142
    Last Post: 10-22-2016, 05:46 AM
  4. Early heat exchangers 1964/1965
    By Milou in forum Technical Info
    Last Post: 01-14-2014, 10:53 AM
  5. Early 1964 tach and 1965 speedo
    By ixxifan in forum General Info
    Last Post: 06-15-2010, 12:24 PM
