Thread: Question on Rear Bumper Guard Brackets
    Jul 2011
    Chicago Area
    Never notice that my bumper guard brackets are at different heights, the one on the right is about a 1/4" higher and it became obvious when I installed the Amco bar. Any ideas on what may have caused this and what can be done to fix this?
    Name:  IMG_2273 (800x594).jpg
Size:  96.4 KBName:  IMG_2290 (800x597).jpg
    Mike Fitton # 2071
    2018 911S Carrera White
    Senior Member moito's Avatar
    AUSTRIA (tu felix)
    Quote Originally Posted by mfitton View Post
    it is bent....usual parking failure
    Jul 2011
    Chicago Area
    No, look at the top of both brackets the one on the right is higher. Not talking about the Amco bar.
    Mike Fitton # 2071
    AUSTRIA (tu felix)
    looks like one of the bumper corners has been replaced or repaired...note missing hole on the right bracket and extra material towards the center..
    i noticed a slight difference in hight swb vs lwb... it is possible to convert a swb into a lwb corner by cutting the wheel arch edge and changing the side bracket.
    Jul 2011
    Chicago Area
    Ok, I see what you are saying, the right side is missing the whole and has an extra "L" bracket on the left side and is welded to the slam panel. Was this a SWB part that was used without the hole? Left side is not welded to the slam panel like the right side.
    Mike Fitton # 2071
    Jul 2011
    Chicago Area
    Here is a picture of an original right rear bumper and the bracket does not have a hole in it. I am going to assume someone added the "L" bracket to mine on the left side of the bracket and welded it to the slam panel for added support.
    Mike Fitton # 2071
    Jul 2011
    Chicago Area
    Found this picture on the Samba of a right rear bumper and is also has the "L" bracket on it like mine, so is this correct, maybe a replacement part? Samba ad said the part came off of a '73 Carrera RS.
    Mike Fitton # 2071
    Makes sense that this was a 73 change due to bumper impact laws. One of those details I've never really noticed,,,interesting.
