Page 23 of 23 FirstFirst ... 13212223
Results 221 to 230 of 230
Thread: Post your 914s, Whether Original or Modified (hot rods).
  1. #221
    Just picked up this Project 914 last week! Hasn't run in a few years I believe, but had been Auto-X'd. No records whatsoever, all there and looks like it has good bones. Plan is to get it going again and run some local Auto-X's.
    1993 964 C2 GPW
    1973 BMW 2002 Verona (Daily)
    1974 914 2.0 Project A/X (in progress)
    1972 911T 2.4 Webers - SOLD
    89 BMW M3 Lachs - my former DD - SOLD
    https://youtu.be/QrF6VEVh1NQ
  2. #222
    Dec 2013
    Connecticut/Florida
    1971 911S Coupe - Gemini Blue
  3. #223
    Seattle, WA
    Simonjjb ---- Very nice cars and stunning garage set up.
  4. #224
    Dec 2013
    Connecticut/Florida
    Quote Originally Posted by beaker View Post
    Thanks...it keeps me sane and learning..with the great help from here and 914world.
  5. #225
    1971 Porsche 914-6 just finishing up
    Finishing up a nearly 5 year conversion/resto project on a 1971 914-4.
    Something of a narrow body GT.
    Rothsport 2.7 MFI engine, GT hoods, full Elephant Racing suspension, upgraded brakes, etc.
    Still has the key on the steering column....had to keep some memories of the former car.
    Some recent pics that Avant Garde Collection (of BAT fame) recently took of the car.
    -Doug
    2022 Carrera 4S Oslo Blue
    1977 Martini Edition 924
  6. #226
    -Doug
  7. #227
    Full spec list:
    1971 Porsche 914-6 Conversion
    Full nut and bolt restoration. Car entirely stripped down to bare metal, repairs made on a rotisserie.
    New Porsche color, Carrara Weisse.
    Engine
    Rothsport built 2.7 MFI engine on 7R engine case. NOS Mahle 8.5:1 pistons/cylinders, S cams, S spec heads, all new internals (intermediate gears, valves, etc)
    MFI pump modified with RS space cam, rebuilt by MFI Werks (Mark Jung)
    Throttle bodies rebuilt to S/RS spec by Burningham Performance
    Amber fan shroud by Series 900
    Restored fan by Mark Motshagen
    Custom 1-5/8” stainless steel header/heat exchangers
    Dansk single outlet sport exhaust
    Custom engine wiring harness
    Factory 914-6 oil tank with GT style cap
    Pertronix points and Parts Klassic solid state CDI unit with matching coil
    Clewett Engineering spark plug wires
    New high performance engine cooler (Stoddard)
    Transmission
    Completely rebuilt for Rothsport by Gordon Ledbetter
    A, E, KA, Q, and Y close ratio gearing.
    930 GT ZF limited slip from Guard Transmission
    904 factory main-shaft
    Heavy duty bearing plate
    Side shifter conversion
    All new parts inside (synchros, bearings, operating sleeves, etc) where needed
    Lightweight high torque starter
    Rebuilt CV joints, Sway-A-Way 930 axles
    Wiring/electrical/instrumentation
    NOS 1971 Porsche 914-4 chassis wiring harness
    LED headlights, taillights
    Euro conversion on the front turn signals
    TN1/TN2 amber fog lights with rear fog light
    All NOS Euro lens: front, rear, side marker
    Gauges rebuilt/modified by North Hollywood Speedometer
    Becker Europa stereo with Alpine speakers and Hirschmann antenna
    Restored dual tone factory horns
    Lightweight hi-tech Anti-Gravity lithium battery
    Chassis
    Rust and minor collision repair
    GT chassis reinforcing kit along with Engelmann interior reinforcing kit
    Provisions made for retractible seat belts
    All metal work done by Cary Kutter/MiddleMotors
    Getty fiberglass GT front & rear hoods using factory latching hardware, undersides clear coated to show the raw amber fiberglass
    Body and paint completed by Superior Auto Body, Gresham, OR
    Entire underside coated in body-color-tinted “Raptor” bed liner
    New Sekurit front windshield
    Majority of hardware throughout car powder coated (Portland Powder Coat) or re-plated yellow or clear zinc (Tru-6)
    All new rubber seals throughout car (Porsche and 914Rubber)
    Custom stainless steel front and rear bumpers
    Ceramic coating muffler heat shield
    Interior
    GTS Classics Watkins Glen sports seats with custom tartan plaid centers (Robertson Modern Hunting) and raw amber fiberglass backs, adjustable lumbar
    New Porsche back pad
    Reupholstered door panels
    New 914Rubber dashboard
    New sun visors
    Dark gray German square weave carpeting from Autobahn Interiors
    Coco mats (Coco mat in rear trunk as well)
    Restored 901 gear shift knob
    Factory dog bone foot rest
    Seat Belt Planet navy retractible seat belts reusing factory hardware and receiver
    Restored factory steering wheel
    Reupholstered rear targa pad
    Glove box re-flocked
    Many items in cabin with new vinyl or reupholstered
    Fuel system
    Stainless steel fuel lines in the tunnel
    All new rubber lines
    New supply fuel pump
    Fuel tank cleaned and sealed
    Restored MFI micro filter assembly
    Brakes
    Front S calipers with black anodized finish and new Zimmerman vented rotors
    Rear 914-6 GT brakes with black zinc finish and new Zimmerman vented rotors
    All caliper work completed by PMB Performance
    All new stainless steel brake lines through the chassis (PMB) and new factory rubber lines at each wheel
    New ATE 21mm master cylinder
    Rear proportioning valve rebuilt by PMB
    Suspension
    Full Elephant Racing suspension
    21mm hollow torsion bars in the front with Bilstein raised spindle RSR struts (heavy duty shocks)
    Front adjustable sway bar
    Porsche turbo tie rod kit
    Coilover sleeve conversion kit (150 lb springs and helper springs) and rear Bilstein sport shocks
    Factory rear sway bar
    Patrick Motorsports adjustable tow link set for the rear
    Wheels/tires
    four (4) 15x6 restored authentic Fuchs alloy wheels with 195/55R15 Toyo Proxes R1R tires
    five (5) 15x5.5 restored Mahle (gas burner) magnesium light alloy wheels with Michelin 185/70VR15 XWX tires
    Build thread is on 914 World: http://www.914world.com/bbs2/index.php?showtopic=249327
    -Doug
  8. #228
    Jul 2011
    Chicago Area
    Hey that tangerine 914-6 looks familiar in Panorama this month!
    Link to more pictures of my car from Parade 2015. https://brucesweetman.smugmug.com/Cl...che-1970-9146/
    Mike Fitton # 2071
    2018 911S Carrera White
  9. #229
  10. #230
    Quote Originally Posted by skinnerd View Post
    Great choices Doug...which makes for great Avant Garde pics. Easily one of best 914s I've seen. I'm partial to the GT flare look but dig that you kept this one narrow bodied.
  1. Replies: 6
    Last Post: 04-09-2013, 06:03 AM
  2. FS: Modified Original Leistritz Sport Muffler
    By YTNUKLR in forum For Sale: 911 Parts
    Last Post: 03-08-2013, 09:13 PM
  3. Modified or O.E.?
    By Fritz A. Ficke in forum General Info
    Last Post: 07-18-2011, 08:45 AM
  4. 4 post vs 2 post lift advice requested
    By caproader in forum General Info
    Last Post: 04-20-2010, 10:56 AM
  5. Value of 1970 E that has been modified???
    By t6dpilot in forum General Info
    Last Post: 10-13-2006, 10:47 AM
