Results 1 to 10 of 16
Thread: Need to replace glass on small (105mm) Durant mirror
    How do you replace the mirror on a large durant? Any specific directions,very interested.I need to do this.
    Thanks David
    Quote Originally Posted by 71-911T View Post
    Thanks David
    Pretty simple. Break and remove the old glass and the black plastic trim ring can be carefully pried out. Drop in a your replacement glass and the trim ring can be snapped back in. I've done probably a dozen without issues.
    JP,thanks for the info.Do you happen to know what the diameter of the new mirror glass needs to be?
    Thanks David
    Good quote by the way..............
    Thanks David
    Sure. I'll measure one for you when I get out to my shop later this afternoon. My local glass guy cuts them for me for $7 each.
    Quote Originally Posted by LiveFromNY View Post
    Looks like 118mm in diameter cut on 4mm glass.
    Jul 2003
    Santa Cruz, CA
    Appears that glass isn't the only thing "making the cut".
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Mar 2016
    U.K.
    I recently did mine too. I used 3mm glass and replaced the gasket at the back too.
