Results 1 to 5 of 5
Thread: WTB: 1972/3 911E MFI Injection system
    I am looking for a complete or partial MFI set up for a 1973 911E that was converted to carburation setup years ago.
    The engine was rebuilt using 2.7 Euro piston and cylinders. I could also use thoughts on this process and a shop that can carry out this task.
    Oct 2005
    wash dc/ los angeles ca
    If in fact the engine was rebuilt with 2.7 Euro Ps and Cs then the natural upgrade would be 2.4 S MFI injection which is nearly identical to the RS 2.7 components even better if you find the 019 RS pump but not absolutely necessary for a very nice torquey engine .
    The intakes and manifolds are identical on the RS and S that year ...
    You are sure to get other suggestions but Ive done this on at least two if not three S engine with the same Euro PCs ,
    Bert
    Oh just saw you requested shop suggestions , that can get sticky depending upon your location ..
    And that is ?
    Quote Originally Posted by 401Kufus View Post
    Dec 2011
    Palm Coast, FL.
    I have a full 2.7 RS Spec MFI system if you want to go that route.
    ESR # 2300
    I have a few MFI pumps, intake manifolds, air filter assemblies and fuel lines unfortunately I’m down under in Australia though. Feel free to hit me up if your in a pickle.
    Hi, i have throttle bodies and stacks in central Europe.
    Numberwise mine are for a 2.0E but the size of the exit is the same.
    My numbers are 901.110.101.0R
    901.110.317.0R
