A fact check from the Illuminate, please? Perhaps it's the photo angle, but it looks like the floor board behind the pedal cluster (picture #5) is for a standard 3 pedal cluster instead of the 2 pedal Sporto version. FWIW, same for the carpet. Having done a Sporto > 5-spd conversion myself, IIRC, the Sporto uses a different 2 slot board and I had to source a 3 slot board to accommodate the clutch pedal.
Not trying to disparage this car and happy to be corrected. Just seems odd that they couldn't use the original or even make a proper wood replacement. The other obvious explanation is either my eyes are deceiving me and/or I don't know what I'm talking about
- MR
Guys,
I think the buyer got a good deal. It’s a matching numbers coupe with an original paint code of gemini blue. Yes, it probably needs about $80K to $100K for a bare metal restoration as well as a engine and transmission rebuild but then you would have a fully sorted longhood in pristine gemini blue paint!
1971 911T/ restoring to S-spec Coupe / Gold Metallic on Black
1995 911 C2 / Guards Red on Cashmere Beige (Sold)
So we should probably define a “good deal” then. $80k-$100k on top of $55k including fees (excluding wait times) brings you into 911S territory![]()
My eyes are drawn to the mismatched decklid badging. The model designation and badge of shame should be gold given the car has the comfort package.
a 4-speed Sportomatic transaxle -which were used on select models from 1967 to 1980I've never seen the Sporto fluffed in quite that fashion. I couldn't see myself ever doing the same.These cars were considered to be "deluxe" 911s, and higher in price compared to a standard 5-speed manual transmission
ESR #1474
ESR #1474
