Results 1 to 4 of 4
Thread: FS: @BaT - No Reserve Auction: Cheapest 911S on the planet!
    You read that right, the cheapest 911S ever. 1972 911S roller, a blank slate. Check it out at No Reserve on Bring-A-Trailer. Finally a 911 anyone can afford.
    https://bringatrailer.com/listing/1972-porsche-911s-19/
    Check out Unobtanium-Inc.com
    New blog posts all the time!
    Quote Originally Posted by Unobtanium-inc View Post
    yes it might be cheap but you will put a small fortune for new body panels; if you have access to very cheap pannels and you can weld then yes this might be worth buying.
    looking on pictures and what parts you would need to fix the car this is easily 20k$ ( maybe less if you can avoid buying if you are good at shaping metal)
    Jul 2003
    Jacksonville Beach
    Ha !
    Add a zero to that $20k
    1962 356 S Cab gone
    1967 911S Coupe
    2008 RS60 Boxster gone
    1973.5 911T targa soft window Gone
    Runge 008 Gone
    2002 996 TT x-50 Gone
    2016 Boxster GTS pts gulf orange
    1969 912 SWT pts green
    Can I be FRANK with you ?
    Live everyday like it's your last .
    Eventually you'll be right.
    VIN Reference = 9112310623
