Hi,
Which one, silver or gold should be the 911 emblem on the glove box door ? (My car is July 65 built, 301506)
http://www.ebay.com/itm/911-gold-glo...06%26rk%3D1%26
http://www.sierramadrecollection.com..._detail&p=7087
Thanks !
JD
Hi,
Thanks !
JD
1970S Coupe, Blood orange #1436
1965 Coupe, Dolphin gray #1506
R Gruppe #647 ; S Registry #1666
Here is the file photo I have for this. After all the years it appears to be silver but I didn't have the chance to remove it and see the under color.
See John Straub's post below for the answer.
If I am recalling correctly, some place along the line the 911 had gold details and the 912 having silver on the dash and rear lid.
Hope this helps.
Last edited by Bobs 67S; 08-06-2012 at 06:50 AM. Reason: Silver. Direct from...John Straub He's the expert on these cars..
Bob
Early S Reg #370
Interesting question. I had an old NOS emblem that was silver. Sold it on the forum last year:
http://www.early911sregistry.org/for...uot-55-Shipped
Kent
E911SR & RGRUPPE
'73 S Coupe #306
We have the best authority John Straub (with a perfect car) and he says Silver...That's the reply we all need. Thanks John.
I'll edit my comments above.
Bob
Early S Reg #370
Thanks Bob,
I had to go out and check...yep, silver.
1962 356 Cab, show car, sold.
Registry #983
R Gruppe #741
Thanks Guys ! It will cost me 58$ instead of 199$ ; good news !
JD
Ok so what to do.
Bought the correct 65 66 silver emblem for my 65. Genuine Porsche part number 901 559 303 20. The pin spacing is 37mm. that is nowhere near the 48mm of the emblem Bob refers to (might as well say the the same as the 49mm spacing I measured on the holes in my glove box lid).
In addition the pins on the Porsche item are not long enough to protrude through the wood/lid and get a clip on. I have no idea what application it is that was provided - doesn't seem to me that even if they rearranged the pin location on the emblem that the size is correct. rant over any thoughts?....
Membership #3255
301022
revivem.co.nz
Maybe u got a rear lid emblem instead?
Registry member No.773
Nope I have deck lid emblems, an original with the correct pin spacing for 65 and repro with the later spacing - its not one of those
I'm not convinced the size of the emblem will accommodate 48mm pin spacing - the only conclusion I can make from this is that the currently supplied emblem dimensions must be different to the original. The emblem is the same as being offered out there currently
Perhaps someone can measure an original in their car and post? (mine was gone)
Membership #3255
301022
revivem.co.nz
