Results 1 to 2 of 2
Thread: 68 911s - 1st drive
    Member 11801's Avatar
    Sep 2013
    Ontario, Canada
    68 911s - 1st drive
    Well, after a 13 year slumber, I changed the fluids, battery, primed the carbs, broke the reverse lever front bracket that connects the throttle to the carbs, removed it, welded it, installed it, broke it again...sigh.... re-installed it, primed it... crank crank crank.... sigh... seemed like a century to start, sputtered and died. Turned it on, waited for the float bowels to fill (Shell 91), cranked and it roared to life.
    Major leaks... none. The few drips from the rocker covers (right side) were expected. It needs heat exchangers and tires. Clutch engagement is at the very top, but it shifted well. ( How do you adjust the clutch? ). Everything works, horn, lights, turn signals, wipers... it's in better shape than a lot of cars I've seen lately.
    I've attached a few pics from this mornings 80k (52 Mile) run. Name:  911-1.JPG
Size:  174.6 KBName:  911-4.JPG
    Early S junkie
    72 914/6 2.0
    73 914/4 2.0
    S Registry: #2750
    Wow, that is a tall aftermarket ducktail. I like the rest though. Enjoy the rolling restoration process!
  1. Replies: 4
    Last Post: 03-03-2014, 11:45 PM
  2. 68 911s - 1st drive
    By 11801 in forum Technical Info
    Last Post: 10-17-2013, 01:49 PM
  3. photos lemans 911s drive
    By fg1227 in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 09-29-2008, 04:09 PM
  4. ANOTHER So Cal Drive 2-25-08
    Last Post: 01-24-2008, 08:37 PM
  5. FUN DRIVE: May 22nd Waves to Vines Drive
    By jtkkz in forum General Info
    Last Post: 05-21-2004, 11:02 AM
