Page 3 of 15 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 145
Thread: 300096
  1. #21
    May 2011
    Chelsea, Québec
    Quote Originally Posted by Carparc View Post
    Are you aware of the engine number issue?
    Is that a yikes or a YIKES????
    Member #1616
  2. #22
    Senior Member moito's Avatar
    AUSTRIA (tu felix)
    1100/2241
    1448/2387
    Franz, those nylon ones were quite common.
    Let me know if I can help, call me anytime, I thoroughly inspected that car in Wiesbaden at a previous owners house last year, wanted to buy it but all the modifications and/or later years parts threw me off considering his price range. I have a lot of pictures available if needed.
    Cheers, Henk.
    Henk
    after i inspected the car at gelderland (pre purchase) i recomended NOT to buy this car for the reasons you mentioned
    and yes we are aware of the engine issue.
    maybe i should have a closer look at my rotten fuel tanks...never reuse the strainers ...
    yep--thanks for offering your help.
    cu
    franz
  3. #23
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
  4. #24
    AUSTRIA (tu felix)
    time for a short update...
    i sourced almost all parts missing or incorrect.
    deck lid grill,steering damper,hood chrest,64 steering rack,headlights,correct nuts and bolts,etc..
    the only hard to find parts are the grey vac formed drip pan...the one i sold just a few days before i got this project..
    http://www.early911sregistry.org/for...648#post826648
    and the early pre production interior mirror
    so if you have some of this stuff for sale let me know.
    status of the restoration is that i still have not decided if i go for acid dip and cataphoretic painting
    or striping paint by water jet
    https://www.youtube.com/watch?v=rKLsUCWRjaQ
    floor pan is almost finished(also on the inside) only need to know the number position of the metal straps that hold the brake lines.
    front fenders(like new 68 ones) are mostly converted to 64
    door corpuses also.
    http://www.early911sregistry.org/for...246#post881246
    so far all metal pices i welded in are original parts...and there are plenty of those if you convert a g-mod rhd floor pan
    still looking for the correct front slam panel or section of it.
    progress is slow but i want to get it all done correct
    3334/3478
  5. #25
    Senior Member VintageExcellen's Avatar
    Feb 2007
    San Diego
    This is a good one to watch. Franz's metal work is excellent.
    Just so you know - Restoration Design is making a new "front lip" panel, the part that holds the front bumper to body seal against the nose panel. This new part will be the 65-early73 type with no drain holes. I have been helping them with details from my original cars so it comes out correct. I don't think it is done yet but very soon.
    Over the last few years I have finally convinced them to remake their rocker panel molds so we can finally get good replacement rocker panels with correct drain holes rather than the bad Dansk type shape. Took forever to find a NOS green rocker panel to scan but I finally did late last year. This is still in the works but I will post more info when I get the first rockers out of the press.
    So there are 3 pieces that will not need to fabricated.
  6. #26
    Atlanta, GA
    The sand blast w water video is interesting, called Dustless blasting here. But this dry ice video is really amazing.
    https://youtu.be/uJ8hEp0ohsI
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
  7. #27
    Atlanta, GA
    this is without sand...only water
    Ah, does it remove rust? Or are you only trying to remove paint?
    Mark Erbesfield
    1957 356A #58648
  8. #28
    Sep 2006
    La Quinta
    There's a guy here in San Diego doing that now...
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
  9. #29
    AUSTRIA (tu felix)
    Quote Originally Posted by merbesfield View Post
    have seen a 911 done with this..was quite astonished that it also removes nasty(not only the easy come off one) rust..not all of it though
  10. #30
    AUSTRIA (tu felix)
    and a few pics of the fender conversion and pedal cluster repair(someone messed up the bolts)
