Results 1 to 10 of 12
Thread: WTB: 2.7 MFI heads
    WTB: 2.7 MFI heads
    Hi, All -
    I am hoping someone has a set of these laying around gathering dust. I *think* these have 16/40 valves and 36/36 ports, I don't want CIS heads. Please correct me if this is incorrect. Let me know what you have, thanks!
    - Rob
    Nov 2003
    Santa Monica CA
    I think all 2.7 heads are CIS as the factory went to CIS starting with the 731/2 CIS 911T. 2.7 cars are 1974 to 1977 all are CIS. The only exception would be the 1974,75,76 Euro Carrera which is 2.7 with MFI but those are vary rare in the USA. So Europe would most likely be your source. Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Nov 2003
    Santa Monica CA
    by the way-- these are 46/40 valves but I think the ports are 35/35 on the CIS heads; not sure on the Euro 2.7 heads. Chris
    May 2006
    CT
    Hi Rob
    The attached chart should help you to understand what you need. Any 2.4 MFI head can be easily converted to 2.7 RS spec by porting and chamfering. I have 2.4 MFI heads should you need them
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Nov 2003
    Santa Monica CA
    I believe if you wanted to use CIS 2.7 heads with Weber carbs,you will be able to do that. Of course you will want MFI heads for your MFI injectors to fit. Chris
    Hi, Tom -
    Thank you for the wonderful chart. If, indeed, I can use an 80mm head (2.4S MFIs) on a 90mm cylinder without undue inefficiency, that does open up the possibilities. I have printed out your chart, and will do some research with my local expert here.
    Raspy Chris -
    Thanks for your input. It appears that the heads I am looking for are the RS MFI heads, made in '73, of course, but also later years (I think '74-76) on Euro MFI Carreras. If Tom is correct, then I should also be looking for '70-'73 MFI 2.4S heads with 46/40 valving, and 36/35 ports, P/N 911.104.008.00. That opens things up a bit!
    Anyone have any heads with that P/N?
    - Rob
    May 2006
    CT
    Rob
    There is a slight chamfer cut around the perimeter of the combustion chamber on the 2.7 heads to accommodate the increase in bore from 84 mm on the 2.2/2.4 to 90 mm on the 2.7.
    That chamfer cut and porting the intakes & exhaust on a 2.2/2.4 MFI head will make you a 2.7 RS head.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Tom -
    You are a fountain of wisdom, thanks! What you are saying that my favorite air-cooled machine shop can make any 2.2/2.4 head into a 2.7 MFI head? Or, are you saying that the shop can make any 2.2/2.4S head into a 2.7 MFI head? Which would you do?
    - Rob
    May 2006
    CT
    They should be able to make any 2.2/2.4 MFI head (T, S or early 2.4T) into an2.7 RS spec head.
    Tom Butler
    1973 RSR Clone
    1970 911E
    FYI, original 73RS heads didn't have the later chamfer in the CC.
