does anyone have background in converting early 911 to 912?
do you mean 912 into a 911,
never heard of anyone doing the other way around
need to weld in the rear engine mounts for 911
As a 912 guy, I was surprised to see the title 911 To 912 Conversion. Needless to say, Harry and I and a few others with both 911's and 912's in their collections can understand the question, if in fact it was the OP intended, but I am sure most others on this forum are scratching their heads and wondering what ren915 is thinking. Inquiring minds want to know.
Keith
BTW, if Magnus ever decides to add a 912 to his collection, we'll know the 912 has "arrived". What do you say Magnus - any plans?
My Garage:
66 912 (Project)
11 Mini Cooper S Hardtop (Daily Driver)
10 Mazda CX9 AWD Grand Tour (Wife's Daily Driver)
05 Nissan Titan LE 4x4 (Haulin & Towin)
various "one design" sailboats / stinky hockey gear / workshop & tools
912 Reg. #0025-C
Early 911S Reg. #1979
Harry Hoffman
1968 912 #3656, burgundy red 'Fritz'. Some mods..
912 Registry charter member #912R0195-C
Early 911S Registry Member #2070
356 Registry Member #36691
http://hoffman912.blogspot.com/
assuming this is a serious post....
after that and contemplating what you're about to embark, you will need the following:
a 912 engine
gear box properly geared for a 912
912 motormounts cut from a parts car (um.. if you need em let me know?)
next you will want to change your tach. if you're going for 100% correct 912 and not just functioning, all of the 912 gauges..
um... 23 rear and 19 front torsion bars (you dont want big bars on a 912).
and now you have made a 911 one better (like turning your amps up to 11.. 912... one better..)
now if turning a 912 to a 911 you would normally upgrade the brakes. if you want to downgrade the brakes when making it one better (a 912), then you can, but obviously bigger brakes are probably OK unless they are turbo brakes which would be extremely overkill.
Harry Hoffman
I don't see anything wrong with turbo brakes on a 912
that's mykind of 912....
Harry Hoffman
Big brakes take more power to accelerate and make the ride worse due to more unsprung mass. You only want as much brake as you need to lock the tires.
Monday March 5, 2012. 8:14am. Remember this day. That is when it all started.
Long live the 912!
John Thompson
