Page 1 of 10 123 ... LastLast
Results 1 to 10 of 100
Thread: How to lose 150+ lbs in a few weeks! 1967 911S race car
    Senior Member Fubawu's Avatar
    I thought I would post my progress on the strict diet my 67S will be going on over the next two months. Car has been a race car most of its life
    and has already seen some weight loss. In regards to the car, original tangerine car, std S trim. Car spent most of its life in California, in 1999 Klubsport purchased
    the car and used it in their HSR series. Around 2010 it was sold and saw very little use. Specs on the car currently:
    -Early 901 gear box with Airport gears and ZF LSD
    -Mag case 2.0 (69 case)
    -GT3 Pump
    -JE pistons 11:1 (est)
    -Carrilo lightweight rods
    -Twin plug heads
    -non counter crank 66mm
    -Elgin cams 314-296
    -Pauter Intermediate/cam gear
    -Weber 46's
    Suspesnion, every bushing, sway bar etc has been ordered from Clint and I will be starting on that as well. No real weight loss but I will keep track.
    I just put the car on the scales and it came in at 2032 lbs. Car is mostly steel ,bumpers are FG. I've created a list of parts etc similar to my thread on my ST I made over on Pelican a couple years ago.
    Obivously I will need FG deck and trunk, might do doors but I want to keep it period correct so modern upgrades like Ti/carbon fibre etc are off the list. If it wasn't possible in the late 60's early 70's when this car ran
    I don't want to do it. We have to have some sort of rule set right? Safety equipment will of course be modern. As I start to post and keep a tally I will hope to get your insight. I'm no expert with SWB cars.
    First race is June 5,6 at Mosport. Currently 2032 lbs goal is 1850 lbs
    Tonight I will look at the muffler and seat set up.
    Cheers John
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    I do have a question re rear wheels. Currently car is on 15x6 Fuchs all around. I'd like to go
    15x7 rear, what is the advantage of the 7R vs the std 7 for the rear if any? Goal is to go 15x6 205/50 and 15x7 225/45 rear.
    Any issues with that? Currently car has spacers and I'd like to cut that weight
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    if you run spacer now(25mm?) go for standard 7"
    Got to the exhaust today. The car had muffled megaphone style and I switched to standard megaphones.
Size:  61.9 KBAttachment 546704
    5lbs saved, total now 2027 lbsName:  IMG_20210310_151140.jpg
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Thanks Dirk, I'll try some std 15x7's
    I also removed the passenger seat and hardware as I don't race with a passenger.
    37lbs saved from the seat/harness, total weight 1990 lbs
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Wanted to upgrade the brakes. Looking at the front calipers I was amazed at how heavy they are.
    I managed to get a set of early Brembos built for the Alfas I believe. Direct replacement which is a major plus.
    Now on to the weigh in:
Size:  61.2 KBName:  IMG_20210311_101058.jpg
    Amazing as I saved just over 10lbs of unsprung weight!
    10lbs saved car total now 1980lbs
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Subscribed! Do these Brembo's fit directly to the 911 axles?
    Quote Originally Posted by superelfje View Post
    Yes SWB 3 inch or LWB rears
    PMB brakes sells them refinished approx $800 a set I believe
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Started what I thought would be a 45 min job.Drilling the pedal board. 2 hours later I'm finished. Not a worthwhile job saved 0.5 pounds off both boards total. I think I lost more in calories doing the work. Final picture is half through the work but you get the idea.
    0.5 lost total weight of the car 1979.5 lbs
Size:  63.4 KBName:  IMG_20210311_164505.jpg
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Quote Originally Posted by Fubawu View Post
    Yes, the Brembo's are 3" mounting, but the caliper you removed looks like an A caliper, and I thought they have 3.5" mounting.
