Page 52 of 55 FirstFirst ... 2425051525354 ... LastLast
Results 511 to 520 of 544
Thread: Final thread on transition from 65-66 model yr!
  1. #511
    Richard, the only one on the list of exceptions that I have is the first, 301981 which happens to have the first 902/1 fitted: 221722 Invoice date happens to be Sept 15, 1965.
    I do not see the conflict that you suggest, but I do see that 1966 MY production began before the August summer break. I do see invoice dates in the gap between July 30 and Aug 16, so while production was shut down, some activities were still functioning. I do see that my last 901/0 serial # was off by 200, so there had to be a typo in the Spec book as seen in post 496 and what I have had in my tables for many years. Factory literature is not immune to typos! I am not infallible either. However I am learning much more today.
    I think it should be remembered that the transition from the straight knee pad to the U-shaped knee pad required a change in the shape of the dash itself. I would think that in as much as possible the body shop would have used up essentially all of the early dash frame first before using the new dash frame later. With the exception of the RHD cars, this may be most defining characteristic of the transition. However, I would like to hear from experienced body men who have been able to carefully examine the differences side by side.
    The other thing I think I should mention is that it appears the 901/0 to 902/1 transition occurred either on a two day split or during one day, July 26. This does not mean that the transmission shop change occurred the same day; In fact it probably happened several days earlier. They would generally have a few days stock on the assembly floor at all times. This was not a just-in-time production facility.
  2. #512
    Senior Member JB21's Avatar
    Apr 2014
    England
    How about this one?
    Tourist delivery paint to sample...very late 901/0
    S-Reg #3160
  3. #513
    That number is a 902/1 gearbox misidentified on the Kardex as a 901/0
  4. #514
    Quote Originally Posted by JB21 View Post
    paint to sample
    79-93147 is an interesting paint code. Can you post a nice photo of the paint badge please.
  5. #515
    No paint badge photo Dave sorry. A while ago..it needed some "polishing" Thanks.
    -Allen-
  6. #516
    Apr 2014
    England
    There was a picture of the paint code plate on a previous thread on this site, I believe.
    https://www.early911sregistry.org/fo...ghlight=302826
    S-Reg #3160
  7. #517
    Apr 2014
    England
    Road Scholars had a late 356 (SC) with the same paint. It was a while back and the car sold, wonder if the original
    owners knew each other?
    https://roadscholars.com/current-off...ow-green-sold/
    S-Reg #3160
  8. #518
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    nice color,
    VW Yellow-Green/LKM 12K
    was also here
    https://www.europeancollectibles.com...he-356sc-coupe
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
  9. #519
    Apr 2014
    England
    If you look carefully at the photos of the accident damaged car on the BHCC advert from 2017, you can still see traces of the original Gelbgrün...
    You can also see that the damage didn't go too far back into the structure of the car.
    S-Reg #3160
  10. #520
    Jul 2014
    bavaria
    erwin_loves_polo
  1. 65/66 final transition #2
    By Zithlord in forum General Info
    Last Post: 01-22-2022, 11:50 AM
  2. Replies: 0
    Last Post: 01-01-2013, 03:11 PM
  3. Case Transition 4R/5R to 7R
    By Guru in forum General Info
    Last Post: 05-05-2008, 06:44 AM
  4. TB 15 Tread Pattern Inspired Watch Band
    By JCR in forum Off Topic
    Last Post: 04-03-2008, 09:07 AM
  5. 4R/5R to 7R transition
    Last Post: 06-11-2007, 05:43 PM
