Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 47
Thread: 901 and early 911 exhaust system
    Restoration newbie.
    Jun 2007
    San Francisco
    Quote Originally Posted by one-two View Post
    That looks like them - what is the publication Andy?
    Robert I found it here: https://www.early911sregistry.org/fo...l=1#post781742
    It looks to me that it's from the 1965 drivers manual.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Mar 2012
    Scotland
    Vojtech, this may help visually.
    https://www.early911sregistry.org/fo...gers-1964-1965 See post 6
    I know no more, maybe someone else does.
    Ian
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    I still do not get it?
    what is needed?
    and what for....which carbs are on the engine?
    which cars? which vins?
    old style heat exchangers / wärmetauscher
    muffler / endtopf
    Richard already made some suggestions and Robert has the FIA solution, I guess?
    and yes, the pictures are from the early manual, f.i the undated 64 edition.
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    Contact Jim Newton at Auto Associates in Canton, Ct. He bought my last (maybe the last on the planet) NOS 901 Heat Exchangers. He was thinking of reproducing them. They were recalled by Porsche in late 65 or sometime in early 66 and replaced with the heat exchanger that we are all familiar with.
    Mar 2016
    U.K.
    I think Vojtech is referring to a muffler. In Europe we call a muffler an exhaust or silencer.
    Restoration newbie.
    Jun 2007
    San Francisco
    I think He is referring to the early style muffler with the additional shield around it in line with the 356 mufflers. I have one and have been in talks through a friend to have a well known outfit make some
    Pics please if you have any
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Quote Originally Posted by ajwans View Post
    This original version was used through the 66 model year. It did not have equal length manifold pipes.
    The much-improved 67 version was developed for the S engine, and had equal length pipes for improved exhaust scavenging.
    When the 67S system was tried on the standard 901/05 engine, it increased the power by 10 PS.
    This brought it too close to the S power output, so restrictor rings were installed for the standard engines to reduce the effect!
    The restrictors were removed on the 901/06 exhaust systems.
    Jon B.
    Vista, CA
    May 2011
    Chelsea, Québec
    Hi Jon
    Where were the restrictor rings placed?
    Quote Originally Posted by Jon B View Post
    Member #1616
    Quote Originally Posted by StephenAcworth View Post
    Hi Jon... Where were the restrictor rings placed?
    Stephen, they were welded into the muffler flanges of the exhaust manifolds.
    Jon B.
    Vista, CA
    andy
    A later muffler is smooth, these have an additional shield around it w heat insulation sandwiched in between.
    On this 912 muffler you can see it better than on that rusty one
    Richard
