Page 29 of 32 FirstFirst ... 192728293031 ... LastLast
Results 281 to 290 of 313
Thread: Early 911S Online VIN Info Reference Thread
  1. #281
    I copied that from my excel. Sorry if it's sloppy. I've been researching for my 70S. Hope it's helpful. Happy New Year.
  2. #282
    May 2019
    Fredericksburg VA
    I am trying to figure out exactly what model I 911 I have. I have found my VIN shows a Base model, but then I found it to be a S. It has the larger brakes and and would lean towards the L. Now I'm really not sure.
    I tried to locate the engine number. I could not find one where I though it should be. Dang!
    I do have a Kardex. I believe the engine to be original. Thanks for the help deciphering.Name:  11835269 Kardex.jpg
  3. #283
    Jul 2013
    Louisville, Kentucky
    https://www.early911sregistry.org/fo...llen+henderson
    You have a 911 normal for the US. They have serial numbers starting with 11835xxx. See the link above for more info.
  4. #284
    Senior Member HughH's Avatar
    Melbourne Australia
    Hi You have a Karmann built USA 1968 911
    The rest seems a bit strange to me although possibly I dont know enough about 68 USA variants
    According to the Spec book the engine number on the kardex is for a 901/14 engine which is the standard 130hp USA engine from 1968 with emission control BUT not for a sporto
    The Sporto engine for those cars, I thought, should be a type 901/17 with a 338xxxx number
    The gearbox number 318xxxx is for a sporto as is the type number 905/00
    When looking at the list of vins I have for similar cars to yours I have a kardex for 3 other USA karmann sportos (all close to yours in vin number, gearbox number etc) and all have 338xxxx rather than 328xxxx numbers for the engine
    i suspect yours is a typo on the kardex and the engine number should be 3380260. That would fit well in with the range of the other three cars I have kardexes for
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
  5. #285
    May 2019
    Fredericksburg VA
    Thanks for the info. However, my engine case does not have a stamped number that I could find. Could the number be somewhere else?
    I doubt the engine was replaced.
    Yes, it is a Karmann body car.
  6. #286
    Quote Originally Posted by Carl S. View Post
    The number should be where the number always is. Why do you doubt it's a replacement? Certainly sounds like it is.
  7. #287
    May 2019
    Fredericksburg VA
    I guess because it only has 51K on the OD. Any ideas why it would be a replacement. You are correct, it is looking that way.
    Perhaps I'm in denial. I was hoping my $1K car was numbers matching.
  8. #288
    Don't feel bad. You're not the first. And at $1k, you're still way ahead of the game.
  9. #289
    May 2019
    Fredericksburg VA
    Thanks, I am grateful no matter what. I have a vintage 911. So Awesome!!!
    I was not concerned about it when we purchased it. Actually, my Wife bought it sight unseen. She rocks.
    Just never crossed my mine that it was not orig. Everything else is - (not the wheels) Denial!!! Nooooooooo.
    I'm the $1K 68 Sprotomatic. I am grateful none the less. It is an awesome project for a newbe.
  10. #290
    Quote Originally Posted by LiveFromNY View Post
    Unless it is a 914/6 motor with the numbers at the other end of the engine.
    But we need to identify the case by the casting part #'s to see if we can identify the period of manufacture. Need to check both case halves, and get the last three characters from each.
  1. 1974 Carrera USA Info Thread
    By CurtEgerer in forum Other Porsche Passions
    Last Post: 06-08-2023, 07:19 AM
  2. Replies: 9
    Last Post: 09-03-2011, 06:42 AM
  3. Longhood Restoration Reference Thread
    By 72targa in forum Technical Info
    Last Post: 05-25-2011, 09:08 AM
  4. early 911s reg mag as a online app.
    By advtracing in forum Membership Questions
    Last Post: 05-04-2011, 07:19 PM
