Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 100
Thread: How to lose 150+ lbs in a few weeks! 1967 911S race car
  1. #51
    Senior Member Fubawu's Avatar
    Got around to removing the rear wheel studs
    Replaced the 100mm for 72mm.
    Turns out it saved just over 0.5 lbs. Not bad as its unsprung weight and only the rears. Something to think about when ordering longer studs.
    0.5 saved 1846 lbs total
Size:  71.9 KBName:  IMG_20210510_200257.jpg
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  2. #52
    Front suspension going back in
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  3. #53
    Swamped out the oil catch can. Went with the original washer bottle over the custom aluminum set up. Saved
    1lbs.
    1lbs saved total weight 1845 lbs
Size:  75.3 KBName:  IMG_20210516_141633.jpg
    Car goes into paint this week.
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  4. #54
    Yes, the Brembo's are 3" mounting, but the caliper you removed looks like an A caliper, and I thought they have 3.5" mounting.
    Hey DAVE YOU ARE RIGHT!! these are 3.5 spacing! What a PITA as my aluminum mounting brackets are set up for 3.5. I was wondering why the new Alu Brembo calipers wouldn't fit?
    I thought it was a caliper depth issue or rotor issue, the obvious option would be bolt spacing. Just a brain cramp on my end. I'll need to get proper SWB mounting brackets ASAP.
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  5. #55
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Quote Originally Posted by Fubawu View Post
    Here over the pond you'd need >= 2 liters of catch can - will the washer bottle have sufficient capacity?
  6. #56
    Odd, this is the factory style bottle used on the 914-6 GT
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  7. #57
    The Netherlands
    Great project! What are you going to use for the interior rear view mirror? If you use the standard mirror then you could possibly loose a few grams using the 914/6 smaller version.
    Cees
  8. #58
    Jan 2011
    Horb a.N. Germany
    Sure but that was back then. Todays FIA / DMSB regulations require 2 liter catchcan up to 2.000 ccm engine capacity engines and 3 liter for larger capacities- but that's a matter of the sanctioning body / regulations.
  9. #59
    Quote Originally Posted by fourteenten View Post
    Cees
    Thats a good point, car currently has a wink style mirror. This saves me from needing a passenger mirror or roll bar clamp mirror. So I could go smaller but then I would have to add another mirror.
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  10. #60
    The Netherlands
    rear view mirror
    This 914/6, some say RSR used them as well is only 220grams and enough sight. I have one in my road/track car.
    Regards,
    Cees
