Results 1 to 10 of 17
Thread: Knee Bolster Fitment 74 to 70
    Does anyone know if the dash knee bolster from a 74 will fit a non AC 70?
    Kevin
    Senior Member Dezzmo's Avatar
    Nov 2006
    Rhode Island
    It looks like they're compatible from 69 to 85.
    http://www.sierramadrecollection.com..._detail&p=2299
    Tim G
    Early S Reg #1017
    RGruppe #663
    73 911T 3.2
    00 Ducati 996 Track Rat
    01 Ducati S4 Monster
    There are slight differences over the years. Technically, they'll all fit but early ones fit the early cars better due to some changes in the mounting posts. Not sure of the exact year(s) the changes occurred.
    Thank you.
    Kevin
    Jan 2011
    DFW TX
    I think the fit around the dash face is different at the outboard corners. '74 on had a thicker dash facia and the corner vents.
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Quote Originally Posted by M_deJong View Post
    Here is a visual on that.
    Top one is from an early LWB car. Later versions began to change, not sure exactly when (G series maybe?). Note corner angles on later car piece.
    Same part number, btw...
    Name:  @knee pad - compare.jpg
    1969 S Coupe #761
    Early S Registry #1624
    There is an even bigger issue with the mounting posts. At some point the square bases at the bottom of the mounting bolts became taller. The result is that later knee pads, when bolted to an earlier car, leave a small gap and don't bolt up flush like the earlier knee pads do. I'm unsure what year this change occurred.
    Aug 2009
    SF Bay Area
    They all fit and the bolts are in the same place. 74 and later ones use vacuum formed vinyl covering and the earlier ones were upholstered. There is a difference there because of the thickness of the vinyl, nothing else.
    Jim
    Jim
    That's not 100% correct, Jim. The bolts are in the same place but there is a definite difference regarding construction of the square base of the bolts that affects fitment from earlier to later cars - again, not sure of the exact dates.
    Feb 2014
    Austin, TX
    Quote Originally Posted by LiveFromNY View Post
    Thanks for confirming my suspicion - I was going to post a question regarding this very topic.
    I recently purchased a pair of knee pads from a '77 for my '73, after verifying that the part numbers were the same. However, when I fit the pad to the dash, there is a noticeable gap where the pad meets the aluminum dash trim piece, plus an even bigger gap at the ends where the vertical part of the knee pads overlap the ends of the aluminum trim pieces. In fact, I don't see how this could possible work with the knee pads I have. I will take a picture and post later, but if someone could let me know if the early knee pads have a recessed area for the trim pieces to fit into at the end, that would be great.
    '73 RoW 911T (project)
    '77 911S
    Early911SReg #2945
