Hi all. Great forum y'all have here. I have a 69 that had a Hofco Burglar alarm installed when new. When I brought the car out of long term hiatus, electrical stuff seemed all weird. After many hours of getting all the Hofco crap out, reattaching wires, repairing wires, according to the diagram, I'm getting electrical stuff sorted out. A few Eurekas & a few WFT's but most all now in working order. Electrical stuff is NOT my strong suit. Thread searches brought me a long way, but I'm outta Aleve, skill, luck, & electrical karma. OK here goes:
Problem: I have NO L/R, F/R turn signals or dash arrows; or 4 way flasher, switch activated, still.
Key OFF: the L & R side parking comes on F&R as it should & the flasher switch activates the flasher in trunk ( I can hear it clicking on & off in steady rhythm) but no lights flash at any corner (or even light for that matter). I have parking/side marker lights & headlight hi/lo beam, interior lights, dash lights (except no arrows for Tsig in tach).
Key ON: all lights same as above + the back up lights, brake lights, fog lights, cig lighter, fan. Wipers & Horn now also work as they should. Pull the Tsig switch down, or move it up, nothing F/R (no Tsig light on at all any corner) or dash arrow, but I can hear flasher clicking. The 4 way flasher pull switch activates the flasher also as I can hear it clicking on & off but same result, no lights at any corner. I changed the multipurpose relay with a new one, no change.
For a brief minute or so when I first hooked the power to the car, the arrows came on L/R but no exterior lights.
I cleaned the large brass type lug grounds at the two battery boxes; the two in the rear at the bumpers; new correct ground strap at battery. Cleaned metal attachment points on body to shiny brass/ sheet metal. I polished with a dremel each fuse connection side and polished each fuse end, replacing each properly, one at a time, in both fuse boxes. All have the correct amp fuse per the books. I verified the color coded wires from the diagram in/out of each fuse connection at boxes, all correct. Took out each screw that holds wires at fuse box & cleaned then replaced. I chased wires under dash to verify connections of right colors etc to each switch and relay bundle. I removed the clam shell and cleaned the Tsig lever switch contacts. Same type cleaning of ends on the emergency flasher switch & headlight switch. I installed a new correct 4 pin NOS (expensive) flasher. Pulled each bulb & cleaned bulb & contacts. Strong battery power.
Also, I lost my note on the tach wiring (senior moments cause more writing of things down as I do them) when I pulled burg alarm stuff from there. On the back of the tach, bottom connections, L to R, I have blue/yellow, then black/purple, then twin brown. Is that right?
Is there a ground from the T sig lever bundle or somewhere I missed? What the hell...I'm outta ideas, so any and all help appreciated to point me in the direction of where do I check next to troubleshoot this?
Thanks, George
