Results 1 to 10 of 14
Thread: horn grill variances
    Senior Member pss's Avatar
    May 2014
    Netherlands
    I have 3 sets of horn grills for SWB. In every set I have a very distinct difference in measures between the left and right grill. The ribs are different, the length is more or less the same and especially the height shows large variance. At first I thought I have grills of different years, but it is always in the same direction for all 3 sets.....could be of course but if I would always hit such chance, I'd move to Vegas.
    Not yet though....maybe the moulds used at the time were different. Anybody any similar experience?
    The funny thing is that on my car currently in restoration the sets fit perfectly, as if it were made to fit at the time.
    The below shows the measures of one set (in mm), where you see that the height differs some 3-4 mm, IE ~5% (compare B and A measures)
    The thickness of the standing rib near the front hood differs 1.4 mm, >15% at the top (measure H)
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    jaques,
    what stamps do you have on the back?
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    May 2014
    Netherlands
    RHS: FG (or FO??) sign and 1
    LHS: FG sign and 3
    on one set, rest need to check.
Size:  128.7 KBName:  IMG_2388.jpg
Size:  100.8 KBName:  IMG_2391.jpg
Size:  121.1 KBName:  IMG_2392.jpg
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    what i have seen is that the upper and lower bar are the ones that make the main difference...those have been machined different in order to correct the fender/bumper/light unit tolarances.
    sometimes also the left and right bars are machined
    and i also think the numbers tell the size.
    also the holepattern is different on some.
    many cars i have seen have different left/right size pairs.
    just had a custy at my shop to find the correct size for his 65.....he failed....he needs a left #3 grill(what you say haul)
    mr. 901 Bob F. knows more
    May 2011
    Chelsea, Québec
    I thoughts there were 3 different sizes denoted by the number stamped on the rear...
    Member #1616
    May 2014
    Netherlands
    My second set has a 4 stamped on the LHS grill, but the RHS has no number marking only the FG sign.
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    Jul 2014
    bavaria
    soory for late reply..had been to disturbed by meetings and vw scandal..
    yes..different and different and not a haiku!
    @jaques
    do they fit to your car?
    @franz
    we should measure them all - btw did u get my mail?
    jaques i have the mentioned size 3 middle stamp 0 driver side...
    and do look for the co driver side 3 to see if it fits...
    erwin_loves_polo
    May 2014
    Netherlands
    my first 2 sets do not have a co driver side 3. Third set is with my restorer, will take some time before I have access.
    Cheers,
    J
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    Nov 2002
    San Dimas, CA
    There's a similar discussion on the "General Info" page of this forum" 4 screw grill!. It's very interesting how these things happen independently.
    When I got my car, it had what I assume was a replacement fender with a two-screw grill. We got the mounting tabs modified and I found a replacement four-screw grill. I also think I have a spare pair of four-screw grills (but one of them's bent). I never noticed that there might be a size variation.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Jul 2014
    bavaria
    @jim
    how did you do the modification on the fender to fit the 4 hole grill?
    and
    btw lucky incident...codriver side 3?available?
    best regards
    erwin_loves_polo
