Results 21 to 30 of 31
Thread: Decals for engine bay
  1. #21
    Good point on the film covering, will pull back and report back.
    This car is 73.5 and CIS.
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
  2. #22
    May 2011
    Chelsea, Québec
    Mine from Canford were the same... remove the film and all should be good... though the texture is still not a perfect match!
    Quote Originally Posted by mac73s View Post
    In looking closely at the top example, it appears that the very thin protective film is still on the sticker and at least from several sets I've received from CANFORD CLASSICS, this film has a green tint. When removed, the true color of the sticker will appear. Just a thought.
    Member #1616
  3. #23
    May 2011
    Chelsea, Québec
    These are my original '66 stickers... none of the current reproductions I've tried are perfect: each has their differences!
    Name:  gas heater 1.jpg
    Name:  gas heater 4.jpg
    Name:  gas heater 6.jpg
    Name:  gas heater 8.jpg
    Name:  gas heater 14.jpg
    Name:  gas heater 17.jpg
    Cheers
    Stephen
    Member #1616
  4. #24
    Senior Member majordad's Avatar
    Dec 2012
    Cork , Ireland
    Thanks Stephen, great info there.
  5. #25
    I believe that the fonts on Manuels will be perfect and as original. So far none of the repo's out there have the correct fonts and spacing. Material, we will have to wait but I know he is working hard on this
  6. #26
    Junior Member Russ Kempnich's Avatar
    May 2017
    Brisbane Australia
    Hi guys, I have a October 65 build 911 (302327) and am trying to figure out the correct engine decal arrangement.
    I know the original 65 cars didn't have any decals but the later 66 model cars did. they were the red bordered type that Canford Classics make.
    This car is an original UK delivered RHD so the actual decals will be different to the US delivered cars but my main problem is knowing whether the car should have them or not?
    Same goes for the air cleaner snorkel and the fan housing decals.
    The car has Webers on it now but originally was built with Solex and will eventually go back to original when I collect all the bits.
    here hoping someone can put this one to bed for me.
  7. #27
    Nov 2002
    San Dimas, CA
    Quote Originally Posted by Russ Kempnich View Post
    Brett Johnson's The 911 & 912 Porsche, A Collector's Guide to Authenticity [page 17] says the foil decals on the rear latch panel appeared in 1967.
    The cars with Solex Carburetors had the Firing Order and Valve Clearance sticker on the snorkel. The earliest car I ever saw with this sticker was 300049 (or maybe 47) so it's safe to bet they all had them.
    I would guess that the Weber-carbureted '66s had a similar sticker but I can't give any evidence.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
  8. #28
    Resurrecting a 6 yr. old thread
    Hi All
    I e-mailed Canford Classics yesterday & they've since informed me they no longer ship overseas - no specific reason given. Anyone have any alternate suggestions or recommendations other than the sources named in this thread? I need a set for a 1970T. Thanks guys.
    Cheers
    JB
    Success is not final, failure is not fatal: it is the courage to continue that counts. - Winston Churchill
    Early 911S Registry Member #3749
  9. #29
    Nov 2002
    San Dimas, CA
    The Lit Meet's just eight days away.
    Jim Alton
    Torrance, CA
  10. #30
    Nov 2003
    Santa Monica CA
    When I went to put on my timing decal on the engine fan, there was no glue left on the foil decal to glue with. Too old it dried up. anybody know a good glue to use on the back of these timing decal that go on the fan housing? Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
