Page 11 of 32 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 316
Thread: 119200154
  1. #101
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by GeorgeK View Post
    Thanks Rick,
    I figured it must be a factory part, but could find *very* few pictures of cares, even 69s' with it. It will stay.
    69 only i`d say....and not even all of em
  2. #102
    Not on my '69 Karmann T.....
    Also note my car has a stamped depression "gutter" for the vent hose.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
  3. #103
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Never seen it before. Interesting!
    1969 S Coupe #761
    Early S Registry #1624
  4. #104
    Banned
    Nov 2004
    Scottsdale, AZ
    George, now you can transport your dumbbells and driveway pavers without fear of collapsing the vent hose.
  5. #105
    Cleaned the ignition wires. Quite some perished rubber, but the wires and connectors turned out very nice. The cap is new, rotor has some minimal corrosion that I could lightly sand out.
    One connector in the rotor cap had more corrosion than the others, must have taken water in. I sanded it clean, and I wonder if it wil be a problem down the line. Am I better off replacing it?
    Second question: the 901 gearbox support has perished cracked dried rubber silentblocks. Anyone besides Wevo offer rebuild/parts for these?
  6. #106
    George, I have a box full of the plugs ends from 30+ years ago. A new wire set original style is around $100. Looks like you spend some time on these. As far as the trans mount, find a good used one, they are not hard to find. I must have a couple.
  7. #107
    Powdercoating 1st batch. They did cover the holes for the enrichment in the air filter cover. Not that I'll use them, but they are there.
  8. #108
    I hate to be critical, but it looks a bit to much gloss.
  9. #109
    Hi Rick,
    Agreed. Next batch will be more satin. Not gonna redo these, though.
  10. #110
    Banned
    Nov 2004
    Scottsdale, AZ
    0000 steel wool will fix that.
