Page 13 of 32 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 316
Thread: 119200154
  1. #121
    Thanks Ed,
    I agree that it is likely an accessory loom, and fog lights it might be.
    HOWEVER, it doesn't match the factory wiring diagram, which is why I am asking here, in case someone has already been there. I have spent the best parf of 2 days on the looms and the factory diagrams, and while some differences are obvious to ID, some like that bakelite connector make no sense.
  2. #122
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    My guess is aftermarket period accessory or an obscure factory option, the latter you may have eliminated already if you know what your car came with from the factory
    1969 S Coupe #761
    Early S Registry #1624
  3. #123
    Electrics, continued.
    The front blinker/horn/fog light/headlight harnesses were corroded, cut and damaged. I guess the left side won't be used again…
    Now the right side is enough good to salvage it, despite one broken screw in the pot metal of the blinker. I changed the brown and yellow wires to the headlight connector. Not fun pulling them through the molded on grommet.
    End result is a perfectly useable harness/blinker. Of course it is a US spec blinker, so I might not be able to use it. Oh well, it'll be of use to someone.
  4. #124
    Good stuff George, really enjoying following along. Keep the updates coming.
  5. #125
    About that connector (pic below),
    Found it, in our own garden: http://www.early911sregistry.org/for...sunroof+wiring
  6. #126
    Good work, so who gets credit? You or the assistant?
  7. #127
    Hi Rick,
    For this one, it was me. Way past his bed time.
  8. #128
    Earlier this afternoon. Back from fitting the jig.
  9. #129
    Dec 2013
    Connecticut/Florida
    Quote Originally Posted by GeorgeK View Post
    Looking good!
    1971 911S Coupe - Gemini Blue
  10. #130
    So happy to see forward progress, and you are doing it right.
