Page 4 of 15 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 144
Thread: MFI troubleshooting - high idle, pops and bucks at part throttle
  1. #31
    Sorry Arne, I knew that,,,,just didn't proof read my post well enough.
  2. #32
    No harm, Ed, just lost a little time. And I've got plenty of that.
    Printed this on a card to keep with the tools:
    Name:  Screen Shot 2019-03-31 at 12.54.50 PM.jpg
  3. #33
    I'm not trying to encourage more rabbit holes, but sometimes the thermostat has to shimmed differently. The thermostat consists of 25(?) wafer pairs and then various shims to adjust the cold running characteristics. It could be possible you have to go into that, but for now I'd try to just work on the warm running adjustments. By the way the thermostat housing has to get very warm,,,,I assume yours does?
  4. #34
    Senior Member beh911's Avatar
    Atlanta
    Unless it's a 69 one year only pump
    1969 S Coupe #761
    Early S Registry #1624
  5. #35
    Atlanta
    Your throttle bodies are worn. This summer with fully warmed car your idle will run closer to 2k
    1969 S Coupe #761
  6. #36
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    Quote Originally Posted by beh911 View Post
    It's the same for all the MFI pumps.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
  7. #37
    Sep 2006
    Bend, Oregon
    Thermostat: On the end of the thermostat rod, after the 25 pair of thermo disc's, are various sized shims (from .10mm to 2.0mm) that make the adjustment for how rich the fuel will be at cold starts. One .30mm shim can make a 10 to 15% difference in fuel delivery. When below 32 degrees this will move the main rack for 35% to 45% more fuel for the cold start. Adding shims will lean out the cold start fuel, removing shims will richen up the cold start fuel. Once the thermostats 25 disc's warm up and expand to the max, about 105 to 110 degrees F, it has reached the warmed up condition and stays there till you shut off the engine and it cools way down.
    Mark Jung
    MFI Werks
    R Gruppe #686
  8. #38
    Thanks for sharing your thoughts on this. As noted in post #10 of this thread, that was the first thing I suspected and checked. There are no apparent vacuum leaks there.
    Yes, the thermostat does get hot. It is plumbed to the HE, although it is currently connected with a big rubber hose rather than the double paper hose. But the evidence is that the thermostat is working fine. While the enrichment is present, the part load behavior is very good. Once the thermostat gets warm and enrichment ends is when it starts running badly. So the thermostat function is not in question.
    Quote Originally Posted by 2.5MFI View Post
    Thanks for this explanation, Mark. So there is really no way to know just how much the thermostat is moving the main rack without disassembly and analysis. I don't think I'll go there now.
    The key still seems to be that part load behavior is very good while the 'stat is doing its thing. So that still points to the main rack being lean when at normal temp.
    As noted above, I'm going to recheck base settings of the throttle plates today, before making any other changes. I've got this feeling that I may have them all too tightly closed, and that may be the cause of the very low idle, as well as the perceived richness at idle.
  9. #39
    Atlanta
    Indeed, my bad. It was the number of adjustment clicks that is different in 69. Thanks
    1969 S Coupe #761
  10. #40
    Arne, the air-bypass screws should be able to adjust to the idle speed you want. It is possible that their passages are coked up, but in addition to removing the adjustment screw and cleaning that passage way, there is also a counterbore that comes in from above the throttle plates that can only be accessed after removing the throttle stacks. Another diagnostic tool you might try is a infra-red heat gun. While the engine is running aim the gun at each exhaust pipe as it exits the head and compare exhaust temps. They will be in the 200-275 range. What you are looking for is a cylinder, or cylinders, noticeably different, like maybe 125 when all the rest are higher. That would be a cylinder not working well, maybe a clogged injector. If you find such you can swap it to another cylinder and see if the problem goes with the injector. Given the history of these parts that is a real possibility.
