Thread: '67 Targa shocks
    '67 Targa shocks
    Just thought I'd post these pics for info purposes. The '67 Targa required Boge shocks rather that Koni. Porsche engineers thought that Koni shocks made the ride too rough. Been looking for a while (couple of years) as Boge had discontinued the shocks. Catalog listed the '68 and beyond version as the replacement. Along the way I acquired the '68 version but just recently got some original '67 versions. Slightly different so thought it might be appropriate to post pictures. The '68 version is on the left in each picture. '68 tubes are slightly larger around and the piece folding the rubber grommet is at least a 1/4 to 3/8 inches wider. For what its worth. Member here has another set of the '67 but expect to probably pay in excess of $800.00 Name:  DSC00589.jpg
Size:  133.1 KBName:  DSC00590.jpg
Size:  105.2 KBName:  DSC00592.jpg
    It's a shame Boge does not make replacement shocks for the 67 SWT's. I guess the current choice is KYB (yuk), or Bilstein . If you try to use the wider 68 shock on a 67, the mounting bolt might not be long enough.
    Dec 2012
    Shingle Springs, CA
    I ran into this problem too. I have a 1968 Targa and Porsche Classic has a Koni as a replacement. I spoke to a few other Enthusiast like Harvey Weidman and the general consensus was to run the Koni's on the softest setting or get some custom valved Bilstein's.
    Good Luck in your search. I too wish Boge made a correct replacement.
    Early 911S Registry Member #3767
    Current:
    2010 GT3 Meteor Grey, Carbon Seats and Ceramic Brakes
    1968 911T Targa, Polo Red, Recaro Sport Seats, Deep Fuchs
    1972 911 ST Recreation (Work in Progress) 3.4L Hot Rod
    1983 911SC Bone Stock. Grand Prix White with Sport Seats
    I think I will go with that. Softest setting will still be a bit much even on soft. I live where the paved roads can be terrible.
    Jul 2003
    Jacksonville Beach
    Can u post boge part #
    I might have it
    1962 356 S Cab gone
    1967 911S Coupe
    2008 RS60 Boxster gone
    1973.5 911T targa soft window Gone
    Runge 008 Gone
    2002 996 TT x-50 Gone
    2016 Boxster GTS pts gulf orange
    1969 912 SWT pts green
    Can I be FRANK with you ?
    Live everyday like it's your last .
    Eventually you'll be right.
    Jul 2003
    Jacksonville Beach
    I have a new set with shelf life of boge
    901 333 051 02
    Let me know if that works
    1962 356 S Cab gone
    1967 911S Coupe
    Runge 008 Gone
