Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Looking for a research project
  1. #11
    Senior Member beetle08's Avatar
    Oct 2010
    Seattle, WA
    I started out as a VW guy, and I ran into some pretty interesting topic hunts when it came to split windows, ovals, and early type 3s. Splits, Ovals, and Type 3s were the first of models for VW, so many things changed in the early stages of the production cycle. It was a fun and valuable learning experience. The same thing can be said for the 911/912 during its early stages of development as well.
    Two of the subjects that stood out for me were hardware and electrics: Who supplied hardware for these cars, what were the correct markings, and when did the hardware change? Anything from fender bolts, to light screws, to you name it. A lot of what is produced today is range based i.e. 64-68, vs. 64, 65, 66-67, and 68. When these cars were first coming out, development was continuously happening, so things like hardware, and electrics were constantly changing.
    Another great subject which I ran into when building my 68, was crossover of parts. Same part, from same supplier, different cars. Bosch, SWF, Hella, etc. supplied most all German cars during that era. I had to find a two block ground terminal for my electrical panel and they were nowhere to be found from the usual sources. I finally found one (mind you at an amazingly affordable $30 too!) through a vintage Mercedes Benz supplier.
    I think there's and endless opportunity for topic hunting John!
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 912-6 TR Tribute
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
    1991 Porsche 964 Carrera 2 3.8
    "if you see a fork in the road, PICK IT UP!"
  2. #12
    Nov 2002
    San Dimas, CA
    I might be able to offer a little help on the mirrors. From the September 1965 Accessories Brochure:
    In theory, even the Durant mirror was an option but a small sampling of Kardexes never shows "Außenspiegel links" but some show "Talbot-Spiegel."
    It's possible some folks ordered Talbot mirrors and never got around to mounting them.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
  3. #13
    Oct 2008
    Burford, ON, Canada
    Quote Originally Posted by NeunElf View Post
    Jim, I looked through some of my Kardex, and from 300233 to 6697 I count 19 with Außenspiegel links, 3 with Außenspiegel rechts and one with 2 Außenspiegel. There were others with no side mentioned. Over about the same range I have 15 with Talbot; some links, some rechts, one both, and one loose.
