Looks a little different now…
https://www.ebay.com/itm/1967-Porsch...-/154870488740
Peter Kane
'72 911S Targa
Ad copy --- before it disappears . . .
'. . . fully restored 1967 Porsche 911 R Tribute. This is the lightest, purest and most valuable 911 of all time. Porsche factory built only 4 prototypes and 20 production 911R models which makes this Tribute an extremely rare piece of Porsche history. Original 911R are currently bringing upwards of $1.2MM. This homage to the rare 911R began with an original 911 in Light Ivory with a rust-free chassis. With show quality paint and a highly detailed under carriage, our signature lightweight Porsche weighs in at 1,850 pounds with a combined 2 liter twin plug engine at over 200 horsepower. Gaswerks Garage’s immense effort and labor engineered a skillful product to recreate the Porsche as close to the factory 911R as possible. Its rich, luxurious 911 aesthetics are preserved in this restoration, as well as its renowned air-cooled mechanics and engineering. More importantly, our 911R homage creates an exhilarating, unique experience for an overall effect of a taut and feel-some drivers car. Our Car comes equipped with:
EXTERIOR
LIGHT IVORY
PAINT CODE: 6604 – PER ORIGINAL C.O.A.
BLACK INTERIOR
RUST FREE CHASSIS
FULL RESTORATION ON ORIGINAL 911 CHASSIS
FULLY REPAINTED USING LIGHT IVORY 6604 PAINT CODE
SHOW QUALITY PAINT
UNDER CARRIAGE FULLY DETAILED
INTERIOR
LIGHT WEIGHT SEATS WITH CORDUROY INSERTS
BRITAX VINTAGE SEAT BELTS
911R STEERING WHEEL
ORIGINAL DATE CODED GREEN FACE GAUGES
10K TACH
REFINISHED LEATHER DASHBOARD
NEW SUN VISORS
NEW DOOR PANELS WITH ORIGINAL DOOR PULLS
VINTAGE 4 POINT ROLL BAR
UPDATED SHIFTER WITH NEW COUPLER
REBUILT PEDAL ASSEMBLY WITH NEW BRONZE BUSHINGS
TRANSMISSION
NEW WIRING HARNESS
100L GAS TANK WITH MATCHING SENDING UNIT
2 NEW BENDIX FUEL PUMPS
NEW OIL TANK AND LINES
REBUILT TRANSMISSION WITH POSI UNIT
NEW ENGINE MOUNTS
LIGHT WEIGHT FLYWHEEL
PERFORMANCE CLUTCH KIT
REBUILT AXLES CV JOINTS
NEW SUSPENSION BUSHINGS
NEW KONI SHOCKS AND STRUTS
NEW ALUMINUM FRONT SUSPENSION BEAM
NEW WHEEL BEARINGS FRONT AND REAR
NEW BRAKE SYSTEM – MASTER CYLINDER BRAKE LINES, ROTORS, CALIPERS, BRAKE PADS, STAINLESS BRAKE HOSES
NEW OPTIMA BATTERY & ALTERNATOR
NEW BOSCH HEADLIGHTS
NEW WINDSHEILD AND RUBBER SEAL
NEW REAR WINDOW
R QUARTER WINDOWS
NEW GEAR REDUCTION STARTER MOTOR
NEW CABLES – CLUTCH, SPEEDO, BATTERY, ACCELORATOR
ENGINE
2.0L TWIN PLUG
MAG CASE UPGRADES
DOWEL PIN CASE HALVES
OIL BYPASS MODIFICATION
TIME SERT CYLINDER HEAD STUDS
TIME SERT 8MM STUDS IN CASE
LINE BORE CASE
CHECK DECK HEIGHT
COATED ROD BEARINGS
3.2 CARRERA OIL PUMP
PAUTER RODS
HIGH PERFORMANCE TIMING CHAINS
JE PISTONS
ELGIN CAMSHAFTS
TWIN PLUG HEADS
TITANIUM VALVE SPRINGS
NEW INTAKE
NEW EXHAUST VALVES
VITON ENGINE GASKETS & SEALS
MAGNETTI MARELLI TWIN PLUG DISTRIBUTOR
46MM PMO CARBS
FIBERGLASS AMBER SHROUD
WHEELS & TIRES
ALIGNED AND CORNER BALANCED
15 X 6 FUCH WHEELS
PIRELLI CN 36 TIRES . . .'
