Results 1 to 8 of 8
Thread: FS: @Gaswerks Garage - 1967 911R tribute
    No affiliation......a nice looking 911R tribute build from Gaswerks Garage in NJ. No price....but probably not cheap.
    https://www.gaswerksgarage.com/car/1967-porsche-911-r/
    JEFF BRINTON
    ESR #1572
    1968 911N
    1974 914 2.0L
    2023 Macan
    SOLD - 1967 911N / 1968 911L / 1967 911N / 1969 912 / 1991 964 C2 / 2013 991.1 / 2008 987 Cayman
    Oct 2008
    Burford, ON, Canada
    305971
    6604
    November 2018 previous post:
    http://www.early911sregistry.org/for...l=1#post994977
    Hemmings Classified
    1967 Porsche 2.0L 911 Coupe, Ad #2156438
    VIN: 305971
    Engine: -
    Trans: 130397
    Color: White/Black
    Mileage: -
    Price: US$69,000
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
    Early 911S Registry #548
    Oct 2018
    Orange County, California
    Stunning build. $275k.
    1957 356A Cab Condor Yellow
    1970 911E Targa “CONDA G”
    1970 911T3.2 “Meatballs”
    1972 911T2.5 “AWBRGN”
    1972 911T Targa Glaserblau
    1976 911S Talbot Yellow
    Senior Member Sixtyseven911's Avatar
    Feb 2015
    Los Angeles
    Looks like it was pretty good car to start with....
    ESR # 3177
    Wonder why they didn’t put the oil tank in the “R” position.
    FS: 305971 'R' Replika
    Quote Originally Posted by Cal View Post
    . . . 911R tribute build from Gaswerks Garage . . .
    '. . . Gaswerks Garage is proud to present our fully restored 1967 Porsche 911 R Tribute. This is the lightest, purest and most valuable 911 of all time. Porsche factory built only 4 prototypes and 20 production 911R models which makes this Tribute an extremely rare piece of Porsche history. Original 911R are currently bringing upwards of $1.2MM. This homage to the rare 911R began with an original 911 in Light Ivory with a rust-free chassis. With show quality paint and a highly detailed under carriage, our signature lightweight Porsche weighs in at 1,850 pounds with a combined 2 liter twin plug engine at over 200 horsepower. Gaswerks Garage’s immense effort and labor engineered a skillful product to recreate the Porsche as close to the factory 911R as possible. Its rich, luxurious 911 aesthetics are preserved in this restoration, as well as its renowned air-cooled mechanics and engineering. More importantly, our 911R homage creates an exhilarating, unique experience for an overall effect of a taut and feel-some drivers car. Our Car comes equipped with:
    EXTERIOR
    * LIGHT IVORY
    * PAINT CODE: 6604 – PER ORIGINAL C.O.A.
    * BLACK INTERIOR
    * RUST FREE CHASSIS
    * FULL RESTORATION ON ORIGINAL 911 CHASSIS
    * FULLY REPAINTED USING LIGHT IVORY 6604 PAINT CODE
    * SHOW QUALITY PAINT
    * UNDER CARRIAGE FULLY DETAILED
    INTERIOR
    * LIGHT WEIGHT SEATS WITH CORDUROY INSERTS
    * BRITAX VINTAGE SEAT BELTS
    * 911R STEERING WHEEL
    * ORIGINAL DATE CODED GREEN FACE GAUGES
    * 10K TACH
    * REFINISHED LEATHER DASHBOARD
    * NEW SUN VISORS
    * NEW DOOR PANELS WITH ORIGINAL DOOR PULLS
    * VINTAGE 4 POINT ROLL BAR
    * UPDATED SHIFTER WITH NEW COUPLER
    * REBUILT PEDAL ASSEMBLY WITH NEW BRONZE BUSHINGS
    TRANSMISSION
    * NEW WIRING HARNESS
    * 100L GAS TANK WITH MATCHING SENDING UNIT
    * 2 NEW BENDIX FUEL PUMPS
    * NEW OIL TANK AND LINES
    * REBUILT TRANSMISSION WITH POSI UNIT
    * NEW ENGINE MOUNTS
    * LIGHT WEIGHT FLYWHEEL
    * PERFORMANCE CLUTCH KIT
    * REBUILT AXLES CV JOINTS
    * NEW SUSPENSION BUSHINGS
    * NEW KONI SHOCKS AND STRUTS
    * NEW ALUMINUM FRONT SUSPENSION BEAM
    * NEW WHEEL BEARINGS FRONT AND REAR
    * NEW BRAKE SYSTEM – MASTER CYLINDER BRAKE LINES, ROTORS, CALIPERS, BRAKE PADS, STAINLESS BRAKE HOSES
    * NEW OPTIMA BATTERY & ALTERNATOR
    * NEW BOSCH HEADLIGHTS
    * NEW WINDSHEILD AND RUBBER SEAL
    * NEW REAR WINDOW
    * R QUARTER WINDOWS
    * NEW GEAR REDUCTION STARTER MOTOR
    * NEW CABLES – CLUTCH, SPEEDO, BATTERY, ACCELORATOR
    ENGINE
    * 2.0L TWIN PLUG
    * MAG CASE UPGRADES
    * DOWEL PIN CASE HALVES
    * OIL BYPASS MODIFICATION
    * TIME SERT CYLINDER HEAD STUDS
    * TIME SERT 8MM STUDS IN CASE
    * LINE BORE CASE
    * CHECK DECK HEIGHT
    * COATED ROD BEARINGS
    * 3.2 CARRERA OIL PUMP
    * PAUTER RODS
    * HIGH PERFORMANCE TIMING CHAINS
    * JE PISTONS
    * ELGIN CAMSHAFTS
    * TWIN PLUG HEADS
    * TITANIUM VALVE SPRINGS
    * NEW INTAKE
    * NEW EXHAUST VALVES
    * VITON ENGINE GASKETS & SEALS
    * MAGNETTI MARELLI TWIN PLUG DISTRIBUTOR
    * 46MM PMO CARBS
    * FIBERGLASS AMBER SHROUD
    WHEELS & TIRES
    * ALIGNED AND CORNER BALANCED
    * 15 X 6 FUCH WHEELS
    * PIRELLI CN 36 TIRES
    Ask = $285k
    (Not mine)
    Quote Originally Posted by Seafeye View Post
    Would have driven the asking price too high.....
