Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 72
Thread: 906/Carrera 6/911R motors - characteristics
  1. #51
    What is LH?
  2. #52
    Langheck
    Means "long tail" in German. There were two 906s: the short tail and long tail.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  3. #53
    Thanks.
    What type of heads did the 906/Carrera 6 engines have?
  4. #54
    They had the 2 liter deep dome head profile and 38mm ports. I [i]think[/] they had 45I/39E valves like the '69S heads, but they might have been smaller. If so the only difference between the 906 and '69S heads would be the ports and twin plugs. Some had MFI ports, some did not.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  5. #55
    May 2005
    Southern California
    With the exception of a 906 Mag Crankcase and the 906 Mag Upper Valve Covers...
    I have the rest of the 906 factory parts so I can build a correct factory motor, several parts are in fact NOS; 906 Center-Lube Camshafts, 906 Center-lube Chain-Boxes and Covers, 906 Mag Intakes, 906 Early Marelli Twin-Plug Distributor, 906 Ti Rod Thrust Bearings, 906 Flywheel, 906 Clutch Disc and Pressure Plate and a set of 906 Cylinders to name a few. This is the results of many years of collecting all the right parts.
    Can anyone help me source a pair of OEM 906 Mag Upper Valve Covers? I gave up on finding the crankcase.
    I can be reached directly via email at AJSERRANO at MSN dot COM. Thank you for your help.
    PS: Recently I was fortunate to sourced a pair of 906 Mag Lower Valve Covers, the 906 Motor Mount and Twin Marelli Coils with Ballast Resistors. Below is a nice pix of a 906 motor recently taken at the Collier Museum.
    906 Mag Valve Covers recently sourced.
    906 Mag Motor Mount recently sourced.
    906 Marelli Twin-Coils
    I also have the 906 exhaust, very cool pieces indeed--and they fit my 914-6 GT for that real authentic 906 sound!
    Here is a sample pix of the 906 Mag Upper Valve Covers I'm missing. Anyone?
    Thx!
  6. #56
    May 2005
    Southern California
    Quote Originally Posted by beginner View Post
    Thanks.
    Some detailed photos of the 906 (1966) Twin Plug Racing Heads...
    Bruce Anderson book.
    Name:  906 Twin Plug Heads Casting Date 9 69 - Photo 00.jpg
    906 Twin Plug Racing Head - NOS
    Name:  906 Twin Plug Heads Casting Date 9 69 - Photo 00a.jpg
    Name:  906 Twin Plug Heads Casting Date 9 69 - Photo 00b.jpg
    906 Twin Plug Racing Head - Casting Number
    Name:  906 Twin Plug Heads Casting Date 9 69 - Photo 00c.jpg
    906 Twin Plug Racing Head - Casting Date
    Name:  906 Twin Plug Heads Casting Date 9 69 - Photo 00d.jpg
    906 Twin Plug Racing Head, ATE Intake / Exhaust Valves, NOS (for lash-caps)
    Name:  906 Twin Plug Heads Casting Date 9 69 - Photo 00e.jpg
    Name:  906 Twin Plug Heads Casting Date 9 69 - Photo 00f.jpg
    Name:  906 Twin Plug Heads Casting Date 9 69 - Photo 00g.jpg
    Free bump!
  7. #57
    May 2005
    Southern California
    These are 914-6 GT Twin-Plug Racing Heads. Same as '906', same casting numbers, but with a later casting date code of 09 69.
    The 906 heads were removed from a factory 914-6 GT race motor many years ago.
    Name:  906 Twin Plug Heads Casting Date 9 69 - Photo 01a.jpg
    They became available and I made the purchase.
    Name:  906 Twin Plug Heads Casting Date 9 69 - Photo 01b.jpg
    Same 906 / GT heads at Ollie's for restoration.
    Name:  906 Twin Plug Heads Casting Date 9 69 - Photo 01.jpg
    Name:  906 Twin Plug Heads Casting Date 9 69 - Photo 02.jpg
    Name:  906 Twin Plug Heads Casting Date 9 69 - Photo 03.jpg
    Name:  906 Twin Plug Heads Casting Date 9 69 - Photo 04.jpg
    Note the casting number and production date. For a 914-6 GT.
    The 906 plastic cars were long gone at this point, but their racing parts production legacy continued in other models.
    Name:  906 Twin Plug Heads Casting Date 9 69 - Photo 05.jpg
  8. #58
    Do you have any detailed dimensions for these valves as we are planning to manufacture the 'solid' rockers later this year and I think that these valves differ from stock valves in their length above the keeper grooves.
    It would be good to know as it may be worth trying to source the correct valves.
  9. #59
    Valves are approx 2mm shorter, when at my notes I'll confirm. Early and late castings differ, in provisions for air injection and MFI casting boss as models for street and racing advanced. Having rebuilt 3 R drive trains in the last 10 years I accumulated a base of knowledge. Gordon
  10. #60
    May 2005
    Southern California
    A few of my measurements with a dial-caliper from a collection of 906 ATE Valves I have.
    Keep in mind that these are used valves and the stem may have been ground.
    Besides all that, my measurements at the time were done rather quickly, taken only for a point of reference.
    Intake ATE 3056 - 45mm / 111mm
    Name:  906 Twin Plug Heads ATE Int Exh Valves - Photo 01.jpg
    Name:  906 Twin Plug Heads ATE Int Exh Valves - Photo 02.jpg
    Name:  906 Twin Plug Heads ATE Int Exh Valves - Photo 03.jpg
    Name:  906 Twin Plug Heads ATE Int Exh Valves - Photo 04.jpg
    Intake ATE 3057 - 39mm / 111mm
    Name:  906 Twin Plug Heads ATE Int Exh Valves - Photo 05.jpg
    Name:  906 Twin Plug Heads ATE Int Exh Valves - Photo 06.jpg
    Name:  906 Twin Plug Heads ATE Int Exh Valves - Photo 07.jpg
    Name:  906 Twin Plug Heads ATE Int Exh Valves - Photo 08.jpg
    ...more to follow.
  1. Replies: 3
    Last Post: 05-14-2013, 07:03 AM
  2. FS: @Symbolic Motors - Carrera RS #056
    By NickP in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 12-25-2012, 06:54 PM
  3. Replies: 4
    Last Post: 11-06-2010, 02:16 PM
  4. 911R engine characteristics
    By preS in forum Technical Info
    Last Post: 03-24-2006, 06:41 AM
  5. airport gears...explain rpm characteristics
    By bob tilton in forum General Info
    Last Post: 02-28-2005, 03:49 AM
