Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 41
Thread: cardboard? front fuse panel cover
    Senior Member 30westrob's Avatar
    Mar 2016
    SE Pennsylvania
    Quote Originally Posted by Wasatch911S View Post
    Yes, perfect! Found the clip on Sierra Madre's website. Is the clip the only item that holds it in place?
    Thanks for the quick reply.
    No. The cardboard cover’s long edge slip into the metal slot on rear side of the fuse panel. The clips only purpose is to hold the hose. Rob
    Lightbulb
    The cardboard panel is held by the pressure of the formed bow shape it is, held between the rear bulkhead of the battery box in front, and a welded boss that forms a slot in back...
    I think that the clip is for cars with the Euro gas tank vent system. My Italian 73S has one.
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    1132 honda snowblower
    member Jackson Hole Ski Club
    May 2014
    South East USA
    these images are from an extremely low mileage un-restored car....It was on the registry, and there are some here that know its history, etc.
    it was a transparent tube that goes thru the clip.
    and for more trouble...see the cardboard on top of the battery....first and only i have ever seen.
    Name:  low milage tube holder.jpg
    Name:  low milage blue.jpg
    Oct 2014
    Wakefield, RI
    I believe that the tube that is in the clip comes from the brake fluid reservoir and goes to the front bulkhead. I have also seen some cars which vent the LF fender vapor canister through this clip but I do not believe that this is correct. Interested in other comments.
    Lot of confusion here re: what goes through the clip on the cardboard cover. Many “low mileage” cars with various tubes placed there. My research informs that the small wrapped cannister hose is the one. Unfortunately the 700 mile 911S car had the cardboard removed so I know of no unadulterated car for reference.
    See this image from PET, #14 is the clip.
    Zed
    Mar 2016
    U.K.
    The clip goes in the centre hole and holds the hose per the picture above. The cardboard itself is held against the side of the battery box and the bracket on the other side.
    Senior Member beh911's Avatar
    Atlanta
    The clip is used to hold part "22" in the PET diagram above. "22" goes to different places, depending on year of car and market.
    In earlier cars, before the charcoal canister, it goes straight overboard behind the washer pump through a hole in the body. This is also the case for RoW cars into later years.
    1969 S Coupe #761
    Early S Registry #1624
    Not so sure about that brake fluid overflow hose going there. Here is the 700 mile car, with authentic white ziplocks holding that tube. Looks to be original placement.
    Zed
    Atlanta
    Quote Originally Posted by Zedone View Post
    Pre 1970 (before the 700 mile S), brake reservoir overflow went into "12" in your diagram. It's "49" in the 65-69 PET diagram (below).
    I think your example Italian market car follows the same diagram. The line in your Italian trunk compartment pic is "51" in this diagram
    Name:  Screen Shot 2020-01-13 at 10.54.13 AM.png
    1969 S Coupe #761
  1. FS: Fuse Panel Cover in Trunk LWB
    By t6dpilot in forum For Sale: 911 Parts
    Last Post: 09-25-2015, 02:41 PM
  2. WTB: Fuse Panel cover - upper (10 fuse) for a 70 E
    By rannett in forum For Sale: 911 Parts
    Last Post: 04-02-2014, 06:18 AM
  3. WTB: Front Fuse Cover Clip
    By DarthMJH in forum For Sale: 911 Parts
    Last Post: 03-15-2014, 05:41 AM
  4. Two silver cardboard fuse panel covers - FS
    Last Post: 07-16-2008, 03:24 AM
  5. WTB - Molded cardboard instrument panel cover
    By rsr1975 in forum For Sale: 911 Parts
    Last Post: 05-25-2007, 08:08 AM
