Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Help needed with 1969 kardex
  1. #11
    Senior Member patrick911's Avatar
    Mar 2007
    Melbourne, AUS
    Are you sure you have the right word?
    ‘Fünfgang getriebe’ (fuenf g-g) would be German for 5-speed gearbox?
    Member #3508
    1973 911 2.4T
    1976 911S -> 2.8RSR replica
    "if nothing goes right, go left!"
  2. #12
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    I am no expert on 912's to say the least.
    However i jut looked at the 912 technical data website and it shows the 5190000 series was a 5 speed 901/05 with a 7:31 R&P OR a 5 speed 902.300/16 gearbox with a 6:29 R&P and it appears that the 6:29 was for 1969. So It MAY be that
    Thanks Hugh!!
    It is a 69 912.
    it only states Getriebe Nr. 5190944
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
  3. #13
    Feb 2012
    Netherlands, Leiden
    See here the options of the Kardex
  4. #14
    Feb 2012
    Netherlands, Leiden
    Thanks Patrick, you are probably right that it is just a 5 speed gearbox. I just never saw that listed as an option lower on a Kardex.
  5. #15
    Dec 2004
    Melbourne Australia
    But as i posted there were two different 5 speed boxes for 912's with the same number configuration That may be a reason to list whether it was a 7:31 or a 6:29 R&P on a Kardex and both, I assume would have different option numbers
    Hugh Hodges
    73 911E
    Melbourne Australia
  6. #16
    Feb 2012
    Netherlands, Leiden
    Hi Hugh, that might indeed be the reason Porsche used that part of the Kardex to put that as a gearbox option.
  7. #17
    Oct 2008
    Burford, ON, Canada
    Each model would have a standard equipment transmission. Any change from that would mean that an optional transmission would be ordered, and thus listed as an option. For a 912 or a 911T it was common for the 4 speed to be the default transmission, thus a five speed would be an optional upgrade.
  8. #18
    Feb 2012
    Netherlands, Leiden
    Thanks for the clarification Dave!
  9. #19
    Hello, does the car still hold its original 9922 if its 9922?
    Only early 69 cars seems to have it?
    Any pictures of interior and the paint plate?
  1. Kardex
    By kouwenhoven in forum General Info
    Last Post: 06-27-2020, 11:20 PM
  2. 1969 911E front trunk photos needed please
    By ruxtonisl in forum General Info
    Last Post: 04-26-2012, 04:16 AM
  3. WTB - 1969 Emergency Switch Needed
    By bxd in forum For Sale: 911 Parts
    Last Post: 03-20-2012, 04:07 PM
  4. 1968/1969 Porsche 911 E your help needed please
    By glyn696486 in forum Technical Info
    Last Post: 09-26-2011, 12:51 PM
  5. 1969 911S performace and weight data needed
    By obrut in forum General Info
    Last Post: 07-10-2005, 04:39 PM
