Page 1 of 26 12311 ... LastLast
Results 1 to 10 of 254
Thread: Projects on our (new to us) 1967 912-6
    Senior Member Jerhofer's Avatar
    Aug 2013
    Rockwell, NC
    Today was the first day of probably many days spent on some projects on our newly arrived 1967 912-6. In my other post announcing its arrival, I mentioned that it has a 3.0 SC motor and tranny among other items. I spent a few days cleaning the interior and polishing and waxing the car while I waited for some parts to arrive.
    The first of those was a beautifully refinished steering wheel from Ramon. The wood wheel that was in the car was too small in diameter and was not my cup of tea. Ramon's refurbished 914 wheels with the hockey puck center not only looks great, it mounts a couple inches closer to the dash than the wood wheel. To me, the wood wheel felt like it was too close to me.
    The rear seats had been removed and carpeted in the manner of the RS cars. However, the carpet was bunched up in one area so I peeled the carpet back, did some alterations to the carpet below and smoothed the carpet the best I could. Not perfect but looks much better now. I also mounted a fire extinguisher in that area.
    Also spent some time with the chrome polish on the turn signal wiper switch arms and on the interior mirror mount. Ran out of time today but some progress was made.
    1967 912 w/3.0 SC motor and tranny, RS door panels, stock body, power windows & brakes, and A/C.
    http://www.early911sregistry.org/for...us)-1967-912-6
    www.jerryforthofer.wordpress.com
    Aug 2013
    Rockwell, NC
    Didn't get out to the garage until after lunch. I spent most of the day cleaning up the trunk area and the spare tire. The battery was not secure when I got the car. Since I was concerned about corrosion from the battery, I ordered an Optima battery. I also found a mount for putting an Optima in a 911. Pretty simple installation. I also re-ran the wires for the oil cooler fan. They were placed under the car just behind the front bumper. I ran them inside the car along the front of the trunk and out to the oil cooler on the right side. I wasn't very comfortable having wires dangling under the front end!!
    Here are some before and after pics of the trunk area.
    Senior Member BrentF's Avatar
    Sep 2012
    Toronto
    That battery ain't going anywhere. Nice enhancements!
    Might want to remove the front trunk seal and turn it around, the gap is supposed to face the front so that air coming in tends to spread the seal, thus sealing better. Don't know why,,,everyone tends to install those backwards?
    Oct 2010
    San Francisco
    Love that steering wheel. Who is Ramon and do you need a donor wheel or does he sell them outright?
    Aug 2013
    Rockwell, NC
    Thanks for the tip. That's the way it was when I got the car.
    Aug 2013
    Rockwell, NC
    Quote Originally Posted by TeeItUp View Post
    He is a forum member here. According to the post below, I got the last steering wheel he had. Maybe he will have some more in the future. The wheel is very nicely done and he was great with his followup.
    http://www.early911sregistry.org/for...-w-hockey-puck
    Aug 2013
    Rockwell, NC
    Quote Originally Posted by BrentF View Post
    Thanks. I still have more work to do in the trunk area. To make the engine swap work and because of adding the power windows, sunroof, and the fan for the oil cooler, many wiring circuits had to be added. I am going to tidy up all of those wires to make them both look better and be safer. I will probably tackle that when I do the A/C installation as I will be adding another circuit.
    Aug 2013
    Rockwell, NC
    I was not happy with the short shifter that had been installed. To reach the gear lever with the short shifter, I actually had to lean forward and the effort was increased considerably. Fortunately the stock shifter was included with the car. I installed it and I like it a lot better. Now it shifts like a real Porsche, somewhat vague with long pulls but much less effort. The short shifter consisted of a shorter lever and a spacer that was installed below the shift tower. Not much science here.
    Next up was removing the air pump. I did not removed the lines under the car as I could see the ones on the left side will be much easier to reach when I backdate the exhaust. I did plug the ends of the lines including the one that went to the catalytic converter.
    The accordion hose to the heater blower fan was in sad shape. I had purchased a new one that required that I transfer the metal sleeve on the blower end to the new piece. I ground off the old rivets and then pop riveted the sleeve to the new hose. Looks much better and will obviously work better.
    While I had everything off I did some cleaning in the engine bay. It now is far from concours ready but much cleaner that it had been. When I have the exhaust off, I will do some cleaning on the bottom of the car. May have to break out the pressure washer.
    Aug 2013
    Rockwell, NC
    Drove the 35 miles or so to downtown Charlotte for the monthly Cars n Coffee. I arrived around 7:15 and we soon surrounded by about any type of car you could think of. Parked next to me was a GT3RS. Made a nice contrast with my car.
    The same fellow who owned the GT3RS also brought a vintage midget racer on a trailer. Very interesting car with a small block Chevy. He bought this car and a 1979 Lightning Indy car once drive by Panch Carter from the same place. He drives the Indy car in vintage races. Very interesting guy to talk with. He recently returned from attending the Goodwood Revival. Very envious!!
    Only one other long hood car there...a '69 911E.
    And a real Speedster was present with lots of patina.
    How about a very early electric car.
  1. W: Looking for a 65 911.. projects ok.
    By 1970rsr in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 04-08-2014, 06:56 AM
  2. projects coming up
    By Boulder Bob in forum Technical Info
    Last Post: 04-05-2010, 10:31 AM
  3. 65 parts car/ projects
    By 1skier in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 10-02-2007, 04:39 AM
  4. Two Projects
    By 72targa in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 09-27-2005, 05:56 AM
  5. Porsche Projects
    Last Post: 09-14-2005, 08:56 AM
