Results 1 to 10 of 13
Thread: Gas smell in the cabin that comes and goes
    Feb 2011
    Spain
    Sometimes if I use the car less frecuently, and in short trips I can smell gas in the cabin. Problem seems to fix itself for a while after a long trip of over 150 miles. There are no visible leaks and car seems to be running pretty well not lean but maybe a bit rich. What can it be?
    Early 911S Registry #2590
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    A couple simple checks, both of which have been my car's issues in past:
    I assume this is for your 69. Try tightening the hose clamps (2) on the vapor box under the cowl. Also, check that the hose that runs from the vapor box to behind the washer pump at front bumper is indeed exiting the trunk area.
    1969 S Coupe #761
    Early S Registry #1624
    Sep 2006
    Maryland
    Rob Abbott
    Dec 2010
    Shell Beach, Calif.
    Rob-
    Thanks for the link. I have this intermittent gas smell when I drive my 912.....
    1969 912 tangerine coupe 82K original miles
    1974 911 red targa 71K original miles
    Tom Michelsen
    Central Coast Heaven
    Shell Beach, California
    [cue Frank Beck . . . ]
    "Fuchi Que Pesta!" - Cheech Marin
    Early S Registry #235
    rgruppe #111
    Banned
    Nov 2004
    Scottsdale, AZ
    Hey! My car has the same problem!
    When I hit a bump its as if something in the seat is activated.
    Problem is compounded by Raisin Bran.
    Feb 2011
    Spain
    Wow! That is a nasty problem :-). But it can really happen...
    Dec 2011
    Victorville CA
    Spray the cracked box with black plasti-dip spray. My fuel odor was the gasket on top of the tank.
    Feb 2011
    Spain
    Thanks for all the suggestions!
  1. Correct '68 Paint/Fnish Sequence for Trunk & Cabin
    By mshaver51 in forum Technical Info
    Last Post: 07-20-2013, 02:38 AM
  2. Replies: 6
    Last Post: 10-01-2012, 12:24 PM
  3. exhaust smell in cabin
    Last Post: 09-19-2008, 05:04 PM
  4. Oil Coolers + Cabin Vent Manifold...
    By ErVikingo in forum For Sale: 911 Parts
    Last Post: 02-20-2007, 12:42 PM
  5. Fuel Smell in Cabin
    Last Post: 03-18-2003, 03:03 PM
