Results 1 to 10 of 18
Thread: Correct Red Horns
    Correct Red Horns
    I have a 1973 S and need to understand correct style red horns and bracket configuration.. Appreciate all advice!
    Agree about search however there is too much conflicting info.. Appreciate clear direction.
    David, what month was your build?
    Feb 2010
    San Francisco, CA
    The info Is actually pretty clear. As the thread indicates, the build month of your car will dictate the type of horns were likely delivered in your car when new.
    Again, many of the changes with the '73 MY occurred after January 1973.
    Pre Jan = banjo style
    Post Jan = trumpet style
    As with EVERYTHING production related on these cars, you will find some degree of variability when it comes to implementation on the production line. Porsche used up their existing parts in the bin and then switched over. Given this detail, you have a little license with a lot of things.
    Really, you had better hope that you need the red trumpet horns as the others are nearly impossible to find. The last nice set of banjo horns I saw sold for around $800... and that was before the demographic had changed from enthusiasts to hedge fund managers.
    E911SR & RGRUPPE
    '73 S Coupe #306
    Aug 2005
    Bucks Co., PA, USA
    Quote Originally Posted by kentf14 View Post
    Very well put. Bargains on parts are very hard to come by these days but good deals can still be had if you're patient and work hard enough to find them.
    ESR #1474
    If your car is post Jan 73 then the Gled 49 post in that thread is absolutelycorrect for 99.99% of cars
    Has special brackets one horn fits on batterybox one on bumper bracket one faces forward one faces down red trumper style
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Question. When did the trumpets were replaced by the "snail style" horns?
    Thx
    Max
    Instagram
    Twitter
    Now comes some more confusion and a question.. I just looked at 1973 E, production 1189 of 1366. Would indicate to me later production. Original 48,000 mi car and it has banjo style horns. Original to the car for sure.. Thoughts??
    Do you mean when did the banjo style replace the snail style or are you asking when did red trumpets replace banjo style
    Clyde Boyer
  1. FS: Horns
    By cjtbt in forum For Sale: 911 Parts
    Last Post: 08-07-2013, 03:36 AM
  2. wtb - red horns
    By phillip in forum For Sale: 911 Parts
    Last Post: 03-25-2012, 12:24 AM
  3. correct horns for a '68?
    By mshaver51 in forum Technical Info
    Last Post: 09-02-2010, 08:34 AM
  4. 69 Horns
    By red67 in forum Technical Info
    Last Post: 03-09-2010, 09:04 AM
  5. WTB 73 horns
    Last Post: 10-09-2009, 07:39 AM
