Rekeying Trunk Lock in a Targa
I decided I would like to get the lock for my trunk release rekeyed (I do not have the key for the lock) so I can lock my trunk when the Targa Top is off.
http://forums.pelicanparts.com/uploa...1075059377.jpg
I can feel the bolts holding the bracket for the the handle assembly at the bottom of the dashboard, but have no clue on how to actually remove them to allow the handle to drop and then allow me to separate the handle from the cable. Or do I loosen the set screw that I have circled. Or do I simply undo the cable in the trunk, pull the handle and find a set screw between the handle and the cable itself?
Has anyone here BTDT?
TIA
