Hello, Cees -
None of your critiques were the .6 points deducted. The knee pads had never been out of the car. I would like to know how you can ID a '74+ one. I also don't know how you can ID a later compressor. Doesn't the gal on the box look pre-'74? ;) None of the judges were smart enough to call me on these things - it was the famous "dirt", and an incorrect bolt from Taiwan, a windshield rubber that needed "cleaning", et cetera.
We had discussions about black behind the grills, and decided against it. How do you know black is "correct"? What is the correct pliers, and how do you know? (see here: post #1
http://www.early911sregistry.org/for...s-amp-Contents)
Thanks, Cees, you are the Man!
- Rob
