Attachment 628109
Link:
https://www.carsales.com.au/cars/det...MjA2OC45LjAuMA..
1967 Porsche 911 R Tribute
https://www.ebay.com/itm/156635078644
For $299,000 I would have at least expected a forward mounted oil sump and external fill. :rolleyes:
Hilarious: “Porsche factory built only 4 prototypes and 20 production 911R models which makes this Tribute an extremely rare piece of Porsche history.”
Or a used car salesman, er...oh wait...;)
Seller’s description for posterity:
1967 Porsche 911 R 369 Miles Light Ivory 2D Coupe Manual
Stock #: A182P
Exterior Color: Light Ivory
Interior Color: Black
Body Type: 2D Coupe
Transmission: Manual
Mileage: 369
Vehicle Description
We are proud to present our fully restored 1967 Porsche 911 R Tribute. This is the lightest, purest and most valuable 911 of all time. Porsche factory built only 4 prototypes and 20 production 911R models which makes this Tribute an extremely rare piece of Porsche history. Original 911R are currently bringing upwards of $1.2MM. This homage to the rare 911R began with an original 911 in Light Ivory with a rust-free chassis. With show quality paint and a highly detailed under carriage, our signature lightweight Porsche weighs in at 1,850 pounds with a combined 2 liter twin plug engine at over 200 horsepower. Gaswerks Garage's immense effort and labor engineered a skillful product to recreate the Porsche as close to the factory 911R as possible. Its rich, luxurious 911 aesthetics are preserved in this restoration, as well as its renowned air-cooled mechanics and engineering. More importantly, our 911R homage creates an exhilarating, unique experience for an overall effect of a taut and feel-some drivers car. 369 miles shown
EXTERIOR:
LIGHT IVORY
PAINT CODE: 6604 PER ORIGINAL C.O.A.
BLACK INTERIOR
RUST FREE CHASSIS
FULL RESTORATION ON ORIGINAL 911 CHASSIS
FULLY REPAINTED USING LIGHT IVORY 6604 PAINT CODE
SHOW QUALITY PAINT
UNDER CARRIAGE FULLY DETAILED
INTERIOR:
LIGHT WEIGHT SEATS WITH CORDUROY INSERTS
BRITAX VINTAGE SEAT BELTS
911R STEERING WHEEL
ORIGINAL DATE CODED GREEN FACE GAUGES
10K TACH
REFINISHED LEATHER DASHBOARD
NEW SUN VISORS
NEW DOOR PANELS WITH ORIGINAL DOOR PULLS
VINTAGE 4 POINT ROLL BAR
UPDATED SHIFTER WITH NEW COUPLER
REBUILT PEDAL ASSEMBLY WITH NEW BRONZE BUSHINGS
TRANSMISSION:
NEW WIRING HARNESS
100L GAS TANK WITH MATCHING SENDING UNIT
2 NEW BENDIX FUEL PUMPS
NEW OIL TANK AND LINES
REBUILT TRANSMISSION WITH POSI UNIT
NEW ENGINE MOUNTS
LIGHT WEIGHT FLYWHEEL
PERFORMANCE CLUTCH KIT
REBUILT AXLES CV JOINTS
NEW SUSPENSION BUSHINGS
NEW KONI SHOCKS AND STRUTS
NEW ALUMINUM FRONT SUSPENSION BEAM
NEW WHEEL BEARINGS FRONT AND REAR
NEW BRAKE SYSTEM MASTER CYLINDER BRAKE LINES, ROTORS, CALIPERS, BRAKE PADS, STAINLESS BRAKE HOSES
NEW OPTIMA BATTERY & ALTERNATOR
NEW BOSCH HEADLIGHTS
NEW WINDSHEILD AND RUBBER SEAL
NEW REAR WINDOW
R QUARTER WINDOWS
NEW GEAR REDUCTION STARTER MOTOR
NEW CABLES CLUTCH, SPEEDO, BATTERY, ACCELORATOR
ENGINE:
2.0L TWIN PLUG
MAG CASE UPGRADES
DOWEL PIN CASE HALVES
OIL BYPASS MODIFICATION
TIME SERT CYLINDER HEAD STUDS
TIME SERT 8MM STUDS IN CASE
LINE BORE CASE
CHECK DECK HEIGHT
COATED ROD BEARINGS
3.2 CARRERA OIL PUMP
PAUTER RODS
HIGH PERFORMANCE TIMING CHAINS
JE PISTONS
ELGIN CAMSHAFTS
TWIN PLUG HEADS
TITANIUM VALVE SPRINGS
NEW INTAKE
NEW EXHAUST VALVES
VITON ENGINE GASKETS & SEALS
MAGNETTI MARELLI TWIN PLUG DISTRIBUTOR
46MM PMO CARBS
FIBERGLASS AMBER SHROUD
WHEELS & TIRES:
ALIGNED AND CORNER BALANCED
15 X 6 FUCH WHEELS
PIRELLI CN 36 TIRES
For us not in the know, can you explain why this car is so far from the original and is a joke? I’m just curious because I don’t know. Thanks, Mark
PS I think it’s funny that the few pics they posted show the engine blowing smoke. Dumb!
It looks like it is probably a nice car, but as noted it is not even a completely accurate recreation of a 911r as they had their oil tanks in front of the rear wheel with an external filler. That being said, the hyperbolic language is what I, and I think others, find amusing. This is an imperfect copy of a 911r that the seller is saying should be considered akin to a 911r in rarity and importance. That’s like saying a mediocre copy of the Mona Lisa should be valued like an original by Leonardo da Vinci.
