Car litterally gives me a headache - with windows up and heater on: sleepy
The heat has always smelled a bit oily/exhausty...
On a trip to CA in Oct driving the Oregon coast - I felt very disoriented, to the point of passing out. Pulled over - aired the car out and sat for about 10 mins until I had my whits about me. From that point forward, when ever the heat is, I have fresh air open at the upper vents.
My uneducated diagnosis is CO poisening. The car has stainless heat exchangers from a leading manufacturer (name escapes me) and has been a problem since day one with them. First question: How best to determine which one is the culprit? (Disconnecting one at a time and driving around seems rather crude). And Second, if one is determined to be leaking, is it repairable or just need to be replaced?
1 Attachment(s)
