Hey all, its Jeremy Simmons (cmoanz) Webmaster for Early911SRegistry
Today I'm offering up my 1970 911T. I will have pictures up shortly.
This is a numbers matching Karmann Coupe in with the correct original Irish Green paint with black interior
I'm asking $30K, I'm willing to listen to offers. Please contact me at cmoanz@gmail.com with offers and/or questions.
91101121325
Engine: 6106221 2.2L
Trans: 901
Paint: Irish Green (#15)
Interior: Black Leatherette (#11)
Options:
US Equipment
Antenna - Left w/Loudspeaker & Noise Suppression
Comfort Package for 911T
The good:
The car is a running driver with no rust issues
It has about ~120K original miles
I'm the 3rd owner, prior owner had the car since the mid 70s always garage kept
Original Zenith 40TIN Carbs rebuilt in excellent condition
All work done to-date is 100% replaceable back to original OEM
Work Done to date:
Rebuilt gas tank with new filters and fuel lines to the pump
Cleaned and POR-15 the front trunk
Removed and patched the non-working after market AC unit
Rebuilt fuel lines in the engine bay to include flow meter
Rebuilt fan, alternator, fan shroud
Rebuilt the pedal cluster and shifter
The upgrades:
Replaced Marinelli Distro with a rebuilt Bosch 0 231 159 008
Added Pertronix Ignitor replacing the points
Added MSD Street Fire CD Ignition replacing the Bosch CDI
Added MSD Blaster Coil
Added Magnecor KV85 Ignition Wires
Added Momo Prototipo (Early 80s model)
Added H4 style headlights
NIB RS style door panels (from Pelican not installed)
NIB RS style carpet kits (from Pelican not installed)
New Turbo upper and lower valve covers
Rain Hats
Newly refinished 15"x6 (Narrow) Fuchs replacing the stock 14" Fuchs
New tires < 500 miles
The bad:
Leaks and burns oil
- Oil Return Tubes leaking on to the headers
- Chain tensioner covers are leaking
- Rear main seal is leaking
Brakes need bleeding and likely rebuilding
Shocks are warn
Original paint is old and dual and likely too thin to buff out
Doors were repainted in the mid 70's due to dings now are shinier then the rest of the car
Chain tensioners have not been updated
OEM Radio missing
