Results 1 to 10 of 14
Thread: Rear Fog Light Bracket for LWB: Production opportunity
    I had several of these fabricated a few years ago and sold all I had. I have been requested by several to make another run, but I need to get a commitment of at least 20 for the price of $50. These fit perfectly, but the appearance is not exact.
    These are made of 16 gauge stainless steel (0.0625"), not zinc plated. They also are flat on all sides and do not have the raised section at the bend.
    I do not have the rear backing plate, however, I just used a combination flat and lock washer with a nut. If I make another run, I will include the bolts, washers, and nuts. I am not sure about the grommet sizing, but could do a little leg work on that also.
    I will post some photos later to show the installation on my car. Drilled 3 holes and mounted with 2 - allen socket head cap screws. The 3rd hole is for the wire, which is suppose to be already waiting for you behind your left tail light assembly. I was able to successfully wire mine into the fog light so that it comes on with the front fogs. A two position switch would be needed if you would like to have them independently on or single stage if you do not have front fogs.
    Note: I just found out that the LWB and SWB are the same.
    Olin - Member #1375
    1972 911T
    Original
    Options added
    I'm in.......
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Registry Member #921
    1972 Bahia Red 911 Coupe #9112100390..."Rudy" SOLD
    1967 Savannah Beige VW Beetle Sedan #117364457..."Heidi"...aka "Tinker Toy"
    No way to do an EXACT copy with the two indentations?
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Can't remember if I have posted this pic from my car before, but here is a reference to an original bracket with all the details described above
    1969 S Coupe #761
    Early S Registry #1624
    Here's mine, sorry it's sideways.
    Olin - Member #1375
    1972 911T
    Original
    Options added
    rpsurfr rpsurfr's Avatar
    Feb 2008
    Detroit MI
    I will take one as well
    thanks
    rpsurfr
    “Every man's life ends the same way.
    It is only the details of how he lived, and how he died that distinguish one man from another.”
    Hemmingway.
    09 Audi S3
    71 911
    79 930
    81 930 Ruf
    98 911
    66 Mustang GT 350
    08 K2500
    28 various European Motorcycles
    1 bicycle
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    I would like 3 of them......maybe now it is possible to manufacture these with the reinforcement. Methods have changed a lot in the last year or so!...cliff
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    Senior Member nvr2mny's Avatar
    Mar 2012
    Kansas City
    I'm in for 2 please...
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    I am in as well
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    less wing, more brass bxd's Avatar
    Mar 2010
    S.F. Bay Area
    I'll take one.
    Jordan
    rally-prepped '69 911T 3.0L
    S Registry #1933
    Vintage Parts & Restoration http://retro-sport.com
