Thread: 911/01 transmission question
    1970 911/01 transmission, I am ready to put back together however I have observed the following.
    I wanted to know if the input shaft bearing in the case should spin and how to measure the runout,.
    In other trans cases I have, that same bearing appears to be fixed and zero play
    here's a short 27 second video explaining my quest
    https://www.youtube.com/watch?v=dawj...wwm5Y33h3pqnGQ
    appreciate any and all input thanks
    oops sorry wrong video posted initially although a real funny one.
    Richard aka le Zookeeper
    early reg #1128
    you can see it spins freely with no play, feels very tight, not sloppy but with a back and forth motion there is a slight play (front to back) gliding on the race.
    early reg #1128
    Mar 2006
    Louisville KY
    That's the outer bearing race and no it shouldn't move at all. I have seen it on quite a few mag case 911/915 transmissions but it was never the reason for the transmission to be disassembled.
    Tony Proasi
    www.stuttgartspecialists.com
    52 split window coupe
    67 912
