Results 1 to 8 of 8
Thread: Lecarra Steering Wheel
    Will a Lecarra wheel mount onto my car directly? Or will I need some sort of adapter to go from the Porsche splines to the splines on the LeCarra (the latter do look a lot like the Porsche splines, but...)
    Thanks.
    Jan 2003
    UK
    Depends whether the hub currently fitted to the LeCarra wheel is a Porsche-fitment one &, if so, whether it is for a '65-'74 or '75-'89 model.
    If you post a picture of the rear of the hub we should be able to tell you.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    ok, if I read the FAQs right, then here is a photo:
    Aug 2009
    SF Bay Area
    Your wheel has a Porsche (60 - 73) hub and turnsignal canceller already fitted. Don't forget to get a "split ring" to fit over the spring or your wheel will wobble like mad and drive you crazy.
    Jim
    Thx - maybe I'm in luck for once on this car(!)
    Junior Member Bearston's Avatar
    Nov 2011
    Toronto
    I bought a LeCarra wheel off of eBay at a very reasonable price and was even more pleased by the fact that a Momo hub adapter was stuck onto it. No, I haven't installed it yet so I don't have any pointers other than the adapter. Hope this helps you to the next step.
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Bearston View Post
    I'd like to see a picture of that!
    Jim
    Nov 2011
    Toronto
    Jim, here are some photos and as you can see I was wrong about the Momo adapter. The Momo adapter is equipped with 6 screws while the LeCarra has 9 lugs attaching it to the hub. The wheel and adapters arrived a couple of years ago as an eBay purchase, but lo and behold when I opened the shipping box not only was there an adapter on the wheel, but there was the Momo too!! I didn't remember that until I opened the box that it's stored in, the photos are to dispell any notions that the Momo adapter will work with the LeCarra wheel.
    Cheers,
    PeterName:  SUC50394.jpg
Size:  99.5 KBName:  SUC50392.jpg
